Things You Would Like to See in the Explorer / Aviator
Forddealz
NY
2020 Ford Explorer ST
If anyone have any Russian friends that might be able to code the active park assist so that it can be pressed with a remote control. If it could self park with a press of a button, they can do it via remote control too.
Join the Elite Explorers for $20. Gets rid of the ads!
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve
Callsign
VE3
I think a mod to enable remote parking could be an insurance issue and possibly a lawsuit in waiting in case of an accident. In 56 years of driving I can't recall ever wishing for or needing such a feature.
twindadST
Kansas City, KS
2001 Ford Explorer Sport
You would need to have a transmitter connected to that feature, which I'm going to go out on a limb and say Ford made sure to not connect those two things together. With the security issues with cars being able to be hacked remotely from Jeep and others, security is a bigger deal in newer cars than people may think.
Forddealz
NY
They have it in BMW 5 series sedan. You can park your car with a press of a remote control while being close to the car standing outside. They would have lawsuits going on too if one of the sensors failed and it would collide with another vehicle outside.
peterk9
Staff member
Moderator
Callsign
VE3
In that case the lawsuit would be against the manufacturer not the individual for an unauthorized modification.
dstewart51
Lake Hughes, CA
2020 Explorer ST
Callsign
KJ7E
- Software update to allow full screen camera views.
- More information displayed on the dash, boost, battery voltage, trans temp
- A way to disable the sound augmentation
- Retain disabling the backup auto braking system (scares the crap out of me when I have my Mountain Bike on the back and forget to turn it off), I turn it off in the driver assist settings, but it does not retain after a re-start
themishmosh
NE Ohio
2020 Explorer ST
-full screen CarPlay
-USB for third row
-retain disable Auto Start-stop
-retain manual shift setting until car turned off
-retain drive mode
-music equalizer settings rather than just bass and treble.
-voice commands more like natural speech (ie. Siri, Google, Alexa)
-lower ride height for ST
-electronic variable shocks
-throttle pedal more forward
-driver's seat: more adjustability, more side bolsters
-less cheap plastic for the interior
-more extension for the steering wheel
-recording capability for front and rear cameras (like TeslaCam)
-full LED lighting for entire car
-keep same hvac settings. for some reason, every time I start the car A/C is on.
Wilkinda65
Lithia, FL
2020 Explorer ST
-USB for third row
-retain drive mode
All of these are great. Additionally I'd like to see when under say 5 mph the 360 view cameras come on automatically to full stop and then go off over 5 mph
UofMEngineer
Michigan
17' Escape Titanium
themishmosh
NE Ohio
2020 Explorer ST
If you hit the M button, it does stay in manual mode.
No it doesn't. If you reverse and go back into drive, it goes back to auto. Sometimes i am just pivoting out and don't want to lose manual.
TonyST
Palm Beach Gardens, FL
2020 Explorer ST
Callsign
KW4WO
I know there are contacts at Ford (UofMEngineer - efforts appreciated) and others that are in this forum but will these lists get passed back to Ford Engineering to seriously think about adding capabilities??
themishmosh
NE Ohio
2020 Explorer ST
Shoot me some examples of things you’ve tried that don’t work.
To me, you shouldn't have to memorize certain keywords from the manual. I asked Siri to navigate to a local store and it did it easily. i said the same thing and the Sync didn't understand me. I believe I said something like "navigate to the Home Depot in Strongsville."
Wilkinda65
Lithia, FL
2020 Explorer ST
I tried “play artist Marilyn Mansion” and it didn’t understand. The System in my 2015 Mustang LE is easier to use voice commands
UofMEngineer
Michigan
17' Escape Titanium
That one should work, assuming Strongsville is in-state. We’re limited to the chain names HERE identifies at that top level. It’s the added step of “Find a Place in Strongsville” that is needed for the more specific locations, like doctor offices, arenas, etc. Main reason it’s not available for specific locations is, since it’s embedded only, it’d drag down processing times massively and accuracy for everything else.
UofMEngineer
Michigan
17' Escape Titanium
Where do you have your media? Phone or thumb drive? There was a rare bug where sometimes the data for music wasn’t getting sent to generate the commands. You can check if that’s the case by saying “browse all artists” and if it parrots back nothing is found, force the database to rebuild via settings -> media player or add/delete a file to force a re-index. When the latest update is pushed out this shouldn’t be an issue anymore.
Also, FYI you don't need to say "Play Artist <X>", there's more flexibility. You can just say "Play X", or things like "Play my music by <X>", "Play a song by <X>", "Switch to music by <X>", etc. There is additional command flexibility as well in subsequent releases.
Wilkinda65
Lithia, FL
2020 Explorer ST
It’s on my iPhone
UofMEngineer
Michigan
17' Escape Titanium
It’s on my iPhone
That could be impacted for the case above. One thing to note is that iOS has a bug now where there can be a mismatch in the media database. So you request song A and get B. Not sure when that’ll get fixed. I’ve had it happen recently with Siri too. It seems like it’s mainly specific to song or podcast names from the times I’ve hit it.
neocvera
Texas
2020 Explorer ST
I definitely feel portrait screen owners should have more control of the content and the amount of realstate dedicated to apps. Everything feels like an afterthought or like quick fix to accommodate the screen orientation.
Like the home area is silly - what’s the point of the phone section there? It doesn’t really do much. Music is generic there as well. Most of the time I’m in the music section and the top 2/3rds of the screen aren’t used very well.
- side mirrors should have an option for turning downward when reversing (software update - possible)
- roof shade should have a one-touch FULL OPEN and CLOSE (software change would be maybe allowing quick double tap on the button to execute this)
- silly picky but here it goes: match the vehicle represented in the info images on screen to your actual vehicle (match the paint/ model) - I doubt it would be a big overhaul, just load paint images and match up to the vin data - I dunno maybe get with the fordpass team on the code)
- clean screen mode/ wallpaper customization
RayoVac
Northern, IN
2020 Explorer ST
As others have noted, another here chiming in on the 10.1 Portrait mode screen. This is supposed to be a "Premium Upgrade" yet we have far worse view capability for things like the Cameras, CarPlay and AA.
It feels like this was rushed to market and Ford software folks only got the time to work on optimizing the Navigation portion to utilize the screen properly. Everything else on the screen seems to be a mash up of trying to fit the content that would exist in the 8.4" Landscape screen into a MUCH smaller upper 1/3 of our 10.1" portrait screen.
For me CarPlay is completely worthless. And I am frustrated every time I put it in reverse and see 2/3 of the screen showing the stupid outline of my vehicle with park sensor info.
I am certainly hoping this was all a rush to market scenario and that behind the scenes the Sync folks are diligently working on making this the Premium upgrade it was supposed to be.
M Annoying things you have found that ford needs to fix Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 32
blwnsmoke Neat things you have found out Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 94
C 2020 Explorer Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 9
S Ford admits mistakes with 2020 Explorer launch, promises to fix problems Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 2
edwx Is there a way to tell when my Explorer was built from the VIN? Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 15
E 2020 Ford Explorer XLT Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 3
L Why I’m NOT running E85 in my 2020 Explorer ST Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 27
H 2020 Ford Explorer XLT transmission issue Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 13
Y worry about new 2020 explorer limited (transmission) Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 26
J 2020 Explorer base looking for LED driving lights Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 5
S 2020 Explorer memory seat issue Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 20
R 2020 Limited Explorer with Serious Transmission Issues Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 2
J 2020 Ford Explorer XLT Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 6
M 2020 Explorer Hybrid CHARGING TIME Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 12
H 2020 Explorer assembly line video. Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 2
J 2020 Ford Explorer Owners Event - Engineers Meeting Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 6
L You can now build a 2020 Explorer BASE with the Build & Price tool Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 1
K 2020 explorer door locks Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 3
S Problem with audio on 2020 Explorer ST Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 0
D 2020 Explorer ST Fuel Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 10
B Poor Gas Mileage in 2020 Explorer Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 14
J Selected to meet with Ford (2020 Explorer) Engineers - INPUT NEEDED Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 76
S Explorer Trade-ins Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 2
K Explorer is down, and possibly out . . Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 8
T 2020 ford explorer less then 2000 miles tire compartment full of water Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 3
B 2020 Ford Explorer ST driver seat issue. Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 1
M Overall impressions of the 2020 Explorer? Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 49
D 2020 Explorer Fault Codes Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 1
T Black Accent Color on 2020 Explorer ST Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 2
B New member. 2020 Explorer ST air issue Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 8
J 2020 Explorer Battery drain Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 2
G 5-Star rating Euro NCAP for 2020 FORD Explorer PHEV Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 0
K 2020 Explorer Limited vs ST Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 7
J Explorer ST - Towing Capacity question Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 34
B Buying a 2020 Explorer Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 5
U 2020 Ford XLT Explorer digital speedometer placement Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 5
K 2020 Explorer Transmission Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 24
N Explorer delays Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 0
A Tracking your Explorer with Canadian VIN Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 2
fast_dave 4wd Layout of 4 Cylinder 2020 Explorer Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 0
GeoTracker Explorer Recall Notices Received Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 7
T Do Aviator or Explorer have auto locking? Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 22
ParkM Aviator vs. Explorer: Differences Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 24
R Explorer Windows won't roll up and close Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 4
ParkM Folding Power Mirrors - 2020 Explorer & Aviator Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 11
D 2020 Explorer Wheels Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 1
M Explorer ST - oil pan design? Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 15
M 2020 Explorer brake controller? Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 66
Exit32 View from Beneath a 2020 Explorer Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 13
S 2020 Ford Explorer has top secret problems disrupting dealer delivery Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 11
Similar threads
