sajaylu
- June 27, 2009
- Accomac, VA
- 97 Explr 2-Dr 4.0 SOHC
Hey Guys,
My name is Dave and I have a 1997 Explorer 4.0L SOHC 4WD, It was a hand me down from my aunt who never used it and I recently found out she had good reason. I wanna fix it up and use it cause my Taurus is having transmission trouble... lol I would like a hand from every one who has time and is interested in helping me figure out what to do what what is wrong and or should I just simply give it back.
When you start the car the first thing you notice is its rough Idle... its pretty bad. I went to auto zone and they pulled some codes. I don't remember the codes cause the guys there ripped them off the receipt. In any case it said something about Vacuum lines and the exhaust and fuel pressure.
From what I already know... there is a hole in the exhaust right before the catalytic converter... So thats the Exhaust code there.
She has been using it without a fuel cap... and I am guessing this is where the bad gas mileage and fuel pressure issue comes from
But that one bit about the Vacuum line got me way off. I'm going back tomorrow to get the codes again and imma post an update.
Another this... is after 30minutes or more of driving the O/D light starts to blink. My uncle tells me its a transmission thing. I am sure he is right but when its blinking it has a slight hard shift when its shifting... when its not blinking or when the truck cools down its perfectly fine.
I am assuming since the engine oil is blacker than my keyboard the transmission oil isn't in good shape either.. I checked it and its a slightly dark pinkish color with no silvery stuff... if that makes any sense. my Taurus has silvery stuff and I have to take it easy on it or it will start to slip. Thats another story there.
Lastly on a full tank it might do 200 miles...
This is what I have done to it so far..
Changed the spark plugs, Put some Lucus oil in the engine till I am ready to chance the oil... can't fine a filter, Cleaned the throttle plate and body... new air filter..
At first I was just trying to get it not to idle and suck gas the way it does... but I am in a Taurus auto club and they are a great source of info and thats what lead me to this place.
I am no mechanic but I know some people. and if I can be pointed in the right direction, that would be awesome.
I already plan on changing the Transmission oil & filter and the engine oil and filter.
Also... why is the check engine light not on, on this thing?
Oh yea the driver side window wont roll down... when I hit the button I hear a click... but it does not work, the passenger side works just fine.
Has anyone had their truck act up like mine?
