Thanks Brian, are you sure that the panels will attach the same? That would seem unlikely the way Ford changes stuff. Are you sure that there is an interference problem with the later dash, and the early panels?
I just found two more wheels from a 2000 Limited, and I also got another left rear door panel. My first one was spilled on by deck cleaner. I could get the front door panels, or the three to make a set. Both my 93, my 99, and the 2000 are Limiteds and have the memory seat switch.
I would much rather keep my 93 door panels, because the left and right window switch panels interchange. I will install a second master switch panel in the right door panel. That will give me control of the four windows and mirrors from the right seat. I will also likely be able to add a rocker switch in place of the window on/off button. I will have a right side turn signal switch.
Don
