Maggies_dad
- August 23, 2018
- 2010 Explorer XLT 4x4
2010 Explorer XLT 4x4, V6
Hi all,
I've had this Explorer for a few months. It was a well-maintained fleet vehicle, and I've had no major issues with it. I've been monitoring a tiny coolant leak from the thermo housing. It will only get worse and I will replace it eventually.
So I topped off the coolant yesterday. First I've done this since I bought it. Last night, I loaded up the dog and went for a drive...about 50 miles. I checked the coolant every so often, and saw no sign of leakage on the block or anywhere else. Temp was fine, no problems. Stopped on the way home, parked on a slight incline and left it running while I got out to whiz. Five min later, I came back and saw fluid dripping at a pretty good clip from the rear of the engine area. I didn't get under there to pinpoint the leak. Probably should have.
I pulled forward and checked the fluid, fully expecting it to be coolant, but it was water. Colorless, odorless...water. Felt like water as well. Checked the engine, no signs of leakage on top or below. Temp gauge normal.
I'm wondering what this is about. I've read some things about rain getting channeled/leaking into the floors on driver side. I did once notice wet floor carpet after I first got the vehicle, but haven't seen it since. The carpet is dry now. We have had some heavy rain lately.
I was running the defroster on low, but with heat, not AC. It was a cool evening. Even if I had been running AC, the size of that puddle was larger than what I would expect to see from condensation after just a couple minutes.
Coolant level this morning was unchanged from when I topped it off yesterday.
Any ideas on what this could be?
Hi all,
