Ive been thinking about this for some time and would like some of your opinions on this I want to run 22" wheels staggerd 22x8.5 front 22x10 in rear any pros and cons? thanks for your input guys!
That's a really good question. I would really like to see a 2011+ Ex set up like this. I think mileage wise, your mpg will go down, BUT how much depends on your standard width. If your XLT has the standard 18" rims, that rim width is 8.0". If you have the optional 20" rims, the rim width is 8.5". The pcm computer will be adjusted accordingly. Figure a decrease of 1 mpg per 3" of width.
There are people on here who has 22 x 8.5 on all four - their fronts look really good - the rears look too far inside the wheel well.
Mileage would be a con:thumbdwn:
Tirewear would be a downer - Tire rotation wold be as follows: front with front , rear with rear - NOT a 4 tire rotation (front corner to opposite rear corner, rears moved forward):thumbdwn:
Looks would definitely be a pro
As for oversteer/understeer? IDK. :scratch:
What do you think 8.5 front and 9.5 on rear would be like (versus a 10" for the rear) - harder to find, yes., but would the tires on the 9.5" width look weird or bigger in circumfrence than they would for a 10" rear? I ask because I'm afraid 10" width will make the wheel stick out of the wheel well about a half inch.
What kind/type of rims are you thinking of going with?
