Black Dynomite
- October 5, 2009
- Wellington, New Zealand
- 2005 Ltd 4.6L
Checked your throttle body lately?
I decided to check my throttle body (remove air intake and push open throttle butterfly) and was unpleasantly surprised to see how much black gunk was in there.
So I removed the throttle body and went to work with some clean rags wiping that stuff out. This pic doesnt really show the extent of the buildup, its worse than it looks! Once finished, connected everything back up using a new gasket Fel-Pro 61050. The packaging states for 5.4L Ford trucks 97-98 but Summit had them listed against the 4.6L. It did require a few mm to be trimmed so the holes would align correctly, however I think I probably could have reused the old gasket.
Results
Seemed to idle better and when I took it for a drive, the acceleration hiss/whistle I used to see at certain rpms was gone.
Question - Most of the dried stuff on the back of the butterfly wouldnt come off. I didnt use any solvents so as not to strip any factory coating as per Ford recommendation but is there any safe solvent to use?
Note: I am certain much of this buildup can be attributed to the over-oiled K&N filter I bought. I like the FIPK but wish K&N would be a little more sparing on the oil or tighten up the quality control. If you have an oiled air filter, I recommend checking both your throttle body and MAF sensor. Also, check them a few days after you recharge the filter too. And go easy on the oil.
Results
