ALYZ1FLR
- November 16, 2001
- MOBILE ALABAMA
- 91 Eddie B. 4x4
For those that have done the throttle cable mod on older explorers beware!! You must also adjust your kick down cable at the same time. More power being applied with out out the proper shift down is a good way to slip direct clutches and overdrive band and clutches. The amount of slack taken out of the throttle cable should also be taken in the kick down cable. Overall the throttle cable mod. is useless unless you are not achieving W.O.T. because of slack. My appologies to those who believe this mod. to be an improvement. This mod. could cost you a trans.
