PotatoExplorer
- August 15, 2016
- Location
- USA
- Carlisle, PA
- 2008 Ford Explorer Ltd.
Is anyone else replacing Throttle Position Sensors every year or two or is it just me?
Got these P2135 codes this morning - P2135-FF and P2135-P. This is a 2008 Ford Explorer 4.6L with 149k miles.
Looking up past orders:
I replaced in February 2017 on Amazon for a Motorcraft DY1164 (Sold/Shipped by Amazon),
replaced again in March 2018 on RockAuto for Motorcraft DY1164 (Sold/Shipped by RockAuto),
replaced again in January 2021 on Amazon for a Motorcraft DY1164 (Sold/Shipped by Amazon).
I know I replaced the whole Throttle Body sometime in 2016 trying to replace the TPS on the OEM Throttle Body (snapped the bolts holding the TPS to the body. Too much Loctite from the factory. Snapped the extractors trying to extract the broken bolts...) So, replaced the Throttle Body from AutoZone. Came with an older sensor that eventually failed and prompted the February 2017 TPS replacement.
I've inspected all the wires numerous times and nothing seemed bad or out of place. I've peeled back the protective wire bundling to see if the wires underneath were chaffed or damaged and it all looked great. I also don't believe it's the wiring because every time I do replace the TPS, it does eliminate the errors for an extended period of time.
Should I be looking into replacing the pedal this time? The only thing that keeps me from purchasing a pedal is that, again, when I replace the TPS, the errors are eliminated for extended periods of time.
I feel like I'm either having terrible luck with continuously purchasing bad TPS batches or I've got a bigger issue on my hands...
