Ticking noise under a load 5.0 302
SMASHEK
Ohio
98 EB 5.0 AWD 4dr
I have a 1998 X with a 5.0 302. I hear a ticking noise when the engine is under a load at 1800 to 2000 rpm. Without a load (in park) you can't hear the noise so it is very hard to detect where it is coming from under the hood. It sounds a little differnent than a lifter ticking so I think it is not a lifter. Any suggestions would be appreciated.
IAmTodd
4x Explorer Veteran
Johnstown, PA
2015 Jeep
Could possibly be pinging. Does it sound like a marble in a tin can? Is it a steady tick? Could also be the exhaust manifolds leaking. Thats a common problem.
JTX
New Mexico
94 xlt
More then likely its the exhaust manifold leaking.
james t
Moderator Emeritus
Texarkana AR/TX
94 SAS sport
More than likely the passenger side exhaust manifold leaking. :) It could also be the EGR tube on the passenger side exhaust manifold.
SMASHEK
Ohio
98 EB 5.0 AWD 4dr
Is there a common area to check for a leak on the manifold itself? Any reason I hear it only under a load?
james t
Moderator Emeritus
Texarkana AR/TX
94 SAS sport
Usually it leaks at the flange to head area.
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
check the bolts too. mine leaked from there. 3 were only finger tight
SMASHEK
Ohio
98 EB 5.0 AWD 4dr
I'll check it out
Thanks for the advice, I will check it out this Saturday and let you know what I discover.
SMASHEK
Ohio
98 EB 5.0 AWD 4dr
Thanks for the suggestions and ideas. As it turned out, the EGR tube from the exhaust manifold to the EGR valve had a slight visible crack. After I removed it I found a much bigger crack on the back side. No more TICK TICK, love it!
