JoeDirt
- December 27, 2003
- Harrisburg, PA
- '96 Sport
Had a vibration/resonance issue at 45 mph and over 80 mph it sounded terrible (loud humming like being inside of a jet at take-off). Whole truck and steering wheel vibrated and dash rattled. Alignment and tire road force balance were recently done.
Took it to the local dealer…said transfer case rear shaft bearing went and chewed up the casting, causing slop in rear drive shaft. Solution was a brand new borg-warner transfer case from factory and replacement of U-joints. I said ok.
Took the truck on a long drive to the shore over the weekend. Vibration is still there but not as strong as before…same speeds and all. The engine has 165,000 miles on it, but I still think it is a vibration from the drive-shaft.
Any thoughts on what to check next?
