Timing at 16^BTDC and... | Ford Explorer - Ford Ranger Forums - Serious Explorations
not turbo
Everett WA
87 Bronco 2
...it runs pretty well.
Consider: 1987 B2, 2.9l, timing mark physically checked for TDC, and has a white mark showing 10^BTDC...
Set the timing there as per both maintenance books and several web sites, truck runs OK until ~35, then gets gutless.
Re-set the timing so it's at 16^BTDC and it runs great. Passes emisions, everything.
Any conjectures as to why..?
C
CopyKat
You pulling the SPOUT connector out when setting the timing?
I found that 10 was a bit gutless, but having it set at 12 made it feel like a different truck. No difference at 14 so I left it at 12.
not turbo
Everett WA
87 Bronco 2
Yes, did that.
HahnsB2
Battle Ground WA
88 Bronco II
Mine didn't like 12* in the summer time, it would ping a little bit so I dropped it down to 10* again, 12* didn't really seam to make hardly any difference anyways.
