FGH
- December 30, 2007
- Jacksonville, FL
- '96 XLT
Timing Chain Cover Removal
What I've got is a 96 with an OHV V6. A coolant drip started and got worse so in I go. It seemed to be coming from the water pump so that was replaced but I could hear the drip again before I got it refilled. Well on more inspection I find that its coming from the timing chain cover. I go to the Haynes and it says to pull the engine, then the oil pan and then take the cover off. Well I've taken covers off engines before with similar designs and didn't have to pull the oil pan or the engine. Has anyone gotten one of the covers off before with the oil pan in place? Since I was going that far I'd be inclined to replace the chain and gears also. Does the bottom sproket come off with the pan on? THANKS!!!
