timing chain on a v6 | Ford Explorer Forums - Serious Explorations
gharmon
Valley, Al
91 4X4 sport, '96 xlt AWD
Thinking about buying a 2002 v6 explorer. Timing chain is broken. Is this a non interference engine or should I be worried about bent valves?
i believe they are interference engines, depending on which timing chain is broken you may have to pull the engine
If a timing chain has actually broken, The heads will need to be removed for a Valve Job.
