tire mobility kit
t4rest
Mabank, TX
2011 Ltd
The knob needs to be pushed down and turned.
TIO M
Copperas Cove, Texas
2011 LTD X/Platinum 4wd
Word of advice follow the manual on how to store it underneath the seat. For some reason mine was standing up and when I took it in for a sync/mft update. The dealer or I should say tech moved my seat down on it and bent my seat rail after a month and a half of waiting for not one but two emergency replacements parts....so know I finally got it back and in working order.. but I'm not 100% it is back to 100% like when I first got it from my dealer. Just make sure it is laying down and velcroed correctly.
1995E
Maryland
95 + 11 Ex both XLT
When we first got the Explorer back in January, the servicemen gave the tire mobility kit to us directly so we had to put it in ourselves. Maybe the dealer forgot to give it to you guys.
esandye
Oklahoma City
2020 Aviator
2012 XLT 4WD
I definitely do not have the tire mobility kit. Dealer will be getting me one, glad I noticed it now.
Bill #5 Explorer
Chicago Area
2016 Explorer XLT
I'd never use the tire gell in the modility kit. Maybe the pump. For an emergency, I'd use a tire plug and/or my cell phone.
tropicvi
St Croix, US Virgin Islands
2008 Range Rover HSE SC
Compressor kit has a home under the center of the 2nd row on my Base model with tow package... the unit is almost the same as the one that came with my Solstice (the solstice has no spare tire)
2012 XLT 4WD
I finally got my tire mobility kit from the dealer. It is much bigger then I thought it would be. After seeing how big it is, it can barely fit under the front driver seat. Yours can fit under your 2nd row? How? I have a 2012 XLT with BLIS and there is no way even a small kit could fit under the 2nd row. Maybe your seats are different. I should take a picture of my kit....maybe mine is different. It kinda big, I think I will only take it when traveling long distances.
esandye
Oklahoma City
2020 Aviator
Read in the owner's manual, there is a detailed instruction on how to store the tire mobility kit under the drivers seat. I didn't think it would fit well but it is actually a pretty slick install and doesn't interfere with the back seat passengers foot room.
artnalex
Los Angeles
2011 Limited
You need to move the driver seat forward (all the way) and raise the seat as much as possible. Once you have done that....it is easy to store underneath the driver seat.
GWA1
New Castle, DE
2011 Explorer Limited AWD
:thumbsup:
jk60543
Oswego, Illinois
2011 Limited Kona Blue
The mobility kit is for vehicles with the towing option. You can't use the smaller spare while towing so they equip the vehicle with the compressor and "stop leak" type of additive. I thought I read that if the tire sealer is used the tire pressure sensor will need to be replaced.
Spengracin
Fairfield, Ca
2012 AWD Limited
Yes this true of most sensors, using the stop leak, ruins the sensor.
houtzb
Fitchburg, MA
2012 Limited 4WD
Has anyone else with the 2012 with Tow Package received the Tire/Temporary Mobility Kit in their vehicle? My dealer and Ford Customer Service are telling me that this was dropped for the 2012 model.
I looked at my spare tire thinking it might be one that can be used for towing but the sticker on the side states specifically NOT to use if towing a Class III trailer and to use the Tire/Temporary Mobility kit.
GWA1
New Castle, DE
On ford.com, build your own, trailer package still lists it.
See earlier post by Border_Explorer. He got one.
2012 XLT 4WD
Houtzb is correct. I have a 2012MY with tow package and it should come with a tire mobility kit. I did not realize it until about 2 weeks later. Called the dealer and they said yes, should have one. Took a couple of days to get it. The tire mobility kit is actually part of the tow package. If you build an Explorer on the site, add a tow package then look at the details, it should list the tire mobility kit...unless they recently changed it
houtzb
Fitchburg, MA
2012 Limited 4WD
I called Ford Customer Service and was told that the tire mobility kit has been discontinued because it destroys the TPMS sensors. They also told me that if I get a flat while towing to call Roadside assistance.
If you compare the 2011 manual to the 2012, you will see that the tire/temporary mobility kit section has been removed for 2012.
Disappointing...
1995E
Maryland
95 + 11 Ex both XLT
Disappointing...
That is so much bull though. Even if you don't use the gel, you could use the compressor part and pump up the tire after you plug the hole in the tire. They definitely shouldn't have removed the tire mobility kit.
shaneymack
Montreal
2012 Limited
Picked up my 2012 explorer limited with the tow package this week and i don't have the tire mobility kit either. I pointed it out to the saleman and he said that he would, "look into it." Guess i am not getting one!
Holligl
Hoffman Estates, IL
2011 Limited Platinum
Plus, if you decide to play in the sand you could let some air out of the tires and then pump them back up when you are done.
N Help with Tire Size for Explorer Sport 2014 Stock 2011 - 2019 Ford Explorer Discussion 8
R TPMS/Low Tire Pressure Warning Stock 2011 - 2019 Ford Explorer Discussion 8
M Sport wheels and tires with Ford tire sensors Stock 2011 - 2019 Ford Explorer Discussion 7
S 2011 XLT Tire/Rim “Upgrade” Stock 2011 - 2019 Ford Explorer Discussion 1
S What tire/wheel size are you running for winter tires? Stock 2011 - 2019 Ford Explorer Discussion 7
N Tire circumference difference Stock 2011 - 2019 Ford Explorer Discussion 4
P Tallest Tire that will fit a 20" tire Stock 2011 - 2019 Ford Explorer Discussion 4
J 2017 explorer sport tire size Stock 2011 - 2019 Ford Explorer Discussion 14
C Notes on tire sizes Stock 2011 - 2019 Ford Explorer Discussion 2
E Front Rear Tire Wear Question Stock 2011 - 2019 Ford Explorer Discussion 2
B 3rd row seat motors burned out and can't access spare tire Stock 2011 - 2019 Ford Explorer Discussion 5
K Tire Question Stock 2011 - 2019 Ford Explorer Discussion 1
A Tyre / Tire Pressure Monitor Malfunction Stock 2011 - 2019 Ford Explorer Discussion 28
M Spare Tire? Stock 2011 - 2019 Ford Explorer Discussion 13
Z What tire pressure are you running? Stock 2011 - 2019 Ford Explorer Discussion 41
S Full size spare tire storage Stock 2011 - 2019 Ford Explorer Discussion 17
S All Terrian tire noise or bearing? Stock 2011 - 2019 Ford Explorer Discussion 7
A Tire size for 2014 Ford Explorer sport Stock 2011 - 2019 Ford Explorer Discussion 6
B mismatched tire, torque steer, dealer may replace Stock 2011 - 2019 Ford Explorer Discussion 1
J 2017 Explorer 300 miles tire comes off rim!! Stock 2011 - 2019 Ford Explorer Discussion 37
F 16 XP Sport tire pressure, PSI question Stock 2011 - 2019 Ford Explorer Discussion 6
B 1,200 miles, run over a rock, need a new tire.... Stock 2011 - 2019 Ford Explorer Discussion 2
K Tire size question Stock 2011 - 2019 Ford Explorer Discussion 3
A Is this tire still patchable? Stock 2011 - 2019 Ford Explorer Discussion 19
P Winter tire size options for 2015 Explorer? Stock 2011 - 2019 Ford Explorer Discussion 4
T can you read the tire pressure through the obd2 port Stock 2011 - 2019 Ford Explorer Discussion 25
M Explorer Sport - Single Tire Replacement Stock 2011 - 2019 Ford Explorer Discussion 9
4 New to forum Tire question Stock 2011 - 2019 Ford Explorer Discussion 9
2 Tire Size Stock 2011 - 2019 Ford Explorer Discussion 20
C Tire rotation, jack points, lug nut torque spec and TPMS reset Stock 2011 - 2019 Ford Explorer Discussion 20
M Flat tire, an observation... Stock 2011 - 2019 Ford Explorer Discussion 4
M Tire Size help 2014 Sport: 275/50/20 Stock 2011 - 2019 Ford Explorer Discussion 8
S Tire balance and alignment questions...? Stock 2011 - 2019 Ford Explorer Discussion 2
B Tire Pressure Stock 2011 - 2019 Ford Explorer Discussion 16
S 2016 Explorer Sport oversize tire? Stock 2011 - 2019 Ford Explorer Discussion 3
R No tire chains - but can we use these? Stock 2011 - 2019 Ford Explorer Discussion 2
0 Tire question Stock 2011 - 2019 Ford Explorer Discussion 22
1 Max Tire Size Stock 2011 - 2019 Ford Explorer Discussion 31
J 2016 Tire Sizes in IDS - Warning Stock 2011 - 2019 Ford Explorer Discussion 6
J Tire Pressure Sensor Fault under 1k miles Stock 2011 - 2019 Ford Explorer Discussion 16
D bad tire Stock 2011 - 2019 Ford Explorer Discussion 8
P OEM Tire concerns Stock 2011 - 2019 Ford Explorer Discussion 18
C Spare tire cover in cargo area Stock 2011 - 2019 Ford Explorer Discussion 11
1 Tire squeals on slow left turns but not right? Stock 2011 - 2019 Ford Explorer Discussion 1
J Read tire pressure from TPMS Stock 2011 - 2019 Ford Explorer Discussion 0
1 Using spare tire and AWD off Stock 2011 - 2019 Ford Explorer Discussion 16
T 15 Sport does it come with tire psi.. Stock 2011 - 2019 Ford Explorer Discussion 2
J OEM Tire Size: Appearance Package and Sport Stock 2011 - 2019 Ford Explorer Discussion 1
J Spare tire 18" vs 20" Stock 2011 - 2019 Ford Explorer Discussion 4
S Green Color Tire Valve Caps Stock 2011 - 2019 Ford Explorer Discussion 24
Similar threads
