update: after running forscan i got a bunch of codes, it seems that all point to the BCM.
===PCM DTC None===
Successful DTC reading, no error codes found
Module: Powertrain Control Module
===END PCM DTC None===
===OBDII DTC None===
Module: On Board Diagnostic II
===END OBDII DTC None===
===BdyCM DTC B124D:02-8A===
Code: B124D - Tire Pressure Sensor
Additional Fault Symptom:
- General Signal Failure
Status:
- DTC Present at Time of Request
- Malfunction Indicator Lamp is On for this DTC
Module: Body Control Module
===END BdyCM DTC B124D:02-8A===
===BdyCM DTC B1182:00-8A===
Code: B1182 - Tire Pressure Monitoring System
Status:
===END BdyCM DTC B1182:00-8A===
===BdyCM DTC B10F1:14-08===
Code: B10F1 - Key In Switch
- Circuit Short To Ground Or Open
Status:
- Previously Set DTC - Not Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
===END BdyCM DTC B10F1:14-08===
===FCDIM DTC None===
Module: Front Control/Display Interface Module
===END FCDIM DTC None===
===FCIMB DTC None===
Module: Front Controls Interface Module B
===END FCIMB DTC None===
===OCS DTC None===
Module: Occupant Classification System Module
===END OCS DTC None===
===ABS DTC None===
Module: Antilock braking system
===END ABS DTC None===
===RTM DTC U1A00:00-68===
Code: U1A00 - Private Communication Network
Status:
- Test not complete
Module: Radio Transceiver Module
===END RTM DTC U1A00:00-68===
===RCM DTC None===
Module: Restraint Control Module
===END RCM DTC None===
===HVAC DTC B1086:07-08===
Code: B1086 - Air Distribution Damper Motor
- Mechanical Failures
Status:
Module: Heating Ventilation Air Conditioning
===END HVAC DTC B1086:07-08===
===PSCM DTC None===
Module: Power Steering Control Module
===END PSCM DTC None===
===ACM DTC None===
Module: Audio Control Module
===END ACM DTC None===
===SCCM DTC B1380:09-08===
Code: B1380 - Steering Wheel Right Switch Pack
- Component Failures
Status:
Module: Steering Column Control Module
===END SCCM DTC B1380:09-08===
===SCCM DTC B1380:17-0A===
- Circuit Voltage Above Threshold
Status:
===END SCCM DTC B1380:17-0A===
===SCCM DTC U2101:00-08===
Code: U2101 - Control Module Configuration Incompatible
Status:
===END SCCM DTC U2101:00-08===
===IPC DTC U023A:00-0A===
Code: U023A - Lost Communication With Image Processing Module A
Status:
Module: Instrument Panel Control Module
===END IPC DTC U023A:00-0A===
===IPC DTC U0241:00-0A===
Code: U0241 - Lost Communication With Headlamp Control Module A
Status:
===END IPC DTC U0241:00-0A===
===GWM DTC None===
Module: Gateway Module A
===END GWM DTC None===
