RobertFord
- November 14, 2011
- Amsterdam, Netherlands
- 1991 Ford Explorer XLT
Hi All,
After doing a lot of searching on this forum about the appropriate tire pressure.
I am using the formula as described a lot on the internet
Tire_pressure_in_Bar = Maximum_tire_pressure_in_bar * (Actual_weight_on_tire_in_kg/Maximum_weight_on_tire_in_kg) ^ 1.25
The door panel on my X says front weight is 1152kg, and rear is 1338kg.
I'm running some old kind of tire on the front, maximum weight 920kg, pressure 35PSI. The rear are relatively new Bridgestone Dueler A/T 964's, maximum weight 975kg, maximum pressure 44PSI. (Was actually not on the tire? had to look it up)
So, using the famous formula, I ended up with advised pressure of 1.34 bar (19.49 PSI) on the front and 1.89 bar (27.48 PSI) on the rear.
I'm somewhat shocked by these outcomes. (Also, as I had apparently been pressurising my front tire very near the maximum allowed) and am somewhat worried about it. I can't possibly rock 1.34 and 1.9 bar on these tires, right? The front is even lower than Fords famous rollover pressure of 26 psi.
Any insights/recommendations?
As I entered it into excel:
Code:
Variable Description Front Back Formula
A_psi Actual Tire pressure (psi) 19.49 27.48 =A_bar/0.0689476
A_bar Actual Tire pressure (bar) 1.34 1.89 =B_bar*(C_kg/D_kg)^1.25
B_psi Maximum tire pressure (psi) 35 44
B_bar Maximum tire pressure (bar) 2.41 3.03 =B_psi*0.0689476
C_lbs Actual weight on the tire (Lbs) 1270 1475 =C_kg*2.20462262
C_kg Actual weight on the tire (KG) 576 669
D_lbs Maximum tire load (Lbs) 2028 2150 =D_kg*2.20462262
D_kg Maximum tire load (KG) 920 975
