tire size help! | Ford Explorer - Ford Ranger Forums - Serious Explorations
tire size help!
Elcochi1
Location
Wisconsin
Milwakee
2006 ford explorer xlt
Im have 235-70-r16 wheels on my 2006 ford explorer, i want to know if i can put some BFGoodrich All-Terrain T/A KO2 245-70-r16 wheels with a stock suspension & a 0 offset rims, if so will the tires rub when i turn?
jfrracing1
WALLACE, SOUTH CAROLINA
2002 & 01 EXPLORER SPORT
if your rims are the same as my 02 explorer sport i went with 265/70/16 and they only rubbed when turned all the way. then they only rubbed a little bit. the tire height measures 32" mounted on the rim. i added TT and shackles and no problems. is it 2wd or 4x4 ? i ask because my wifes 01 sport is 2wd and it has 235's on it. mine is 4x4 and came with 255's on it.
jfrracing1
Its a 2wd and it came with 235's, the wheels i want to get are 16×7 black rock rims( https://m.summitracing.com/parts/brw-997671240 ) & idk if i can mount them on some 245/70/r16
i believe those rims would work. because ur tire is going to be more centered on the hub than mine are. u figrue the offset i have keeps more of the tire in the wheel well. i have about the same size tire ur talking about getting so i believe they would work. mine only rubbed all the way to the lock and it was minor. these pictures were with no lift at all.
Elcochi1
Location
Wisconsin
Milwakee
What rim size are you running with? I guess i will go with the 245/70/r16
jfrracing1
i have 16" wheel. i have 265/ 70/ 16 on my truck. so u could even go bigger if u want
Elcochi1
Location
Wisconsin
Milwakee
Thanks for your help I will go with the 265's
