sluggish
- January 20, 2014
- Orillia, Ontario
- 2012 Ram 3500
I just picked up a 96 5.0 AWD to use as a donor vehicle for a 30-50's style body swap(haven't found that yet) and I have one question(for now). I do not plan to offroad at all, but would like to put a little meatier tire on it as it will be my daily driver in the winter. I basically am wondering what is the maximum size I could safely go with and not cause excessive/premature wear on the driveline components. I don't need 35's or anything like that, but maybe a set of 31's would look a bit better. However, I don't want to add significant stress to the components just to look a little cooler. If no increase in tire size is recommended for the stock components then I guess I will stick with stock. Keep in mind that the weight of the truck should significantly decrease once the Explorer body is gone.
