EricJRW
- September 28, 2012
- Fort Worth, TX
- 1999 Ford Explorer XLT
CEL is on.
Code is P0302 Cylinder 2 had too many misfires within a predetermined time.
Bought new wires. Bought new plugs.
Getting to spark #2 is a major pain.
I do notice the boot seems to flop around a bit more than the boot on #1.
Manage to get it off and it just does look good so decide to replace wire (only) as a first try.
Now my problems start.
First, I decide it's going to be too hard for me to change the spark plug, so decide on just trying a new wire first. Maybe I'll get lucky.
But I just cant seem to get may hand in a position to get the wire securely on the plug.
No matter how hard I push, it does not seat. I'm also wishing I had used a lubricant, or at least a little dish soap.
I wish I had, because now I can't get the wire off. I'm only pulling on the boot, and can't get a good angle.
So I do my best to push it back on (it does not feel that good, still a bit floppy), and hope for the best. It certainly is not going to be worse, and in fact when I drove the Explorer, it did not drive worse, and maybe a bit better, but the CEL is still on.
So here are my questions:
1. If I got lucky with the wire, should the CEL clear by itself? If yes, does it take some time? If no, does it need to be cleared with the reader?
2. Advice needed on how to get this wire off and on, as I may end up changing the plug.
3. Advice needed on right combination of socket and handle to get to this, and the other 5 plugs.
Thanks so much in advance, Eric
PS. Not sure if it's going to show up in my post, but 1999 Explore, with the 4.0L, SOHC
