Roadrunner777
- February 5, 2011
- Bemidji, MN
- 94 4x4 Sport 88k
I guess I have been on this forum a few years, getting help, trying to help. I frequently see people challenged because they lack a few basic tools specific to the Explorer, things that are easy and cheaper to buy on-line before the crisis hits. Nobody, myself included wants to buy things they may not need in the future. But, my experience suggests these are good investments:
1. The computer doesn't have a fuel pressure sensor. So, a fuel pressure problem really cannot be diagnosed without a fuel pressure gauge, such as this: http://www.amazon.com/Actron-CP7818...&keywords=fuel pressure gauge&tag=53363387-20 You may find one locally at twice the price... your choice.
2. You can try to read computer codes with flashing check engine light. Nothing wrong with that. I can't... I get confused. I got this reader, which includes excellent instructions: http://www.amazon.com/Equus-3145-Fo...id=1374089963&sr=8-6&keywords=odb+code+reader Orielly's usually has this in stock, if you are near a store.
3. This one, if you don't have it, you will come to a grinding halt doing your ball joints. You will not find it locally at any price. The front ABS sensors are secured with... who did this anyway... a 12 point 6mm bolt in a deep recess. There is one and only one socket that works. Here it is: http://www.kahntools.com/6mm-12-pt-torqueplusr-deep-socket-1-4-dr.html
Anyway, that's my experience. I have tried substituting alcoholic beverages, but it really didn't help in the long run. If anyone has additions... have at it!
Added:
4. The MAF is secured with Torx security screws. You might find the tool bits at Ace Hardware. Online at: http://www.amazon.com/Silverhill-Po...1374092846&sr=8-5&keywords=torx+security+bits
5. Spindle nut socket. If you have manual hubs, you need this: http://www.amazon.com/Powerbuilt-648474-Spindle-Socket-Inner/dp/B0015UV6IO For auto hubs, 2-3/8 regular hex socket, but remember it is keyed, and you have to pull the key before you try to remove the nut.
6. I just thought of this. It's not a tool exactly. But, it will save your butt if you take the time. The Exp uses relays for a number of tasks, such as the fuel pump, heater blower, ABS, and so on. They use a generic connection scheme, so one can replace another. So, I will add a relay such as this. http://www.rockauto.com/catalog/moreinfo.php?pk=38944&cc=1119631 but, you should find one at any good car parts store. My point is to buy one in advance and throw it in the glove compartment. It's an easy $10 to spend and will serve you well down the road.
Added:
