Tork tech supercharger? | Ford Explorer - Ford Ranger Forums - Serious Explorations
Aaron95cobrar
I am in the middle of installing a tork tech supercharger on my 02 Mountaineer 4.6l has any body on here performed this swap? Specs are as followed
2002 Romeo alum block
Kellogg 6 bolt forged crank
03/04 Cobra Manley rods
Probe 2618 forged dish pistons
Trick flow 44cc heads
Comp xe262bh blower cams
New trick flow timing set
Tork tech kit
Eaton m112
Join the Elite Explorers $20 Get rid of the ads!
Elite Explorer members see no advertisements, no banner ads, no double underlined links.
. First register on the forum, then join the Elite Explorers to get rid of the ads!
Limited02
Gardner, KS
'02 Limited V8
I am not aware of anyone here that has done the Tork Tech kit. We do have some members that have supercharged their rides, one being a KB 2.2.
Based off your mod list, you will be making very good power. The only concern I'd have is the transmission because they are only good up to the 400+ range before they start having issues.
Get some pictures and numbers up when you can!!!
Aaron95cobrar
lots of mustangs making good power with the 5r55. a good rebuild and some mods 2 cool it and it should be ok.
Aaron95cobrar
A few problems with the swap so far.
1.timing cover is different from the mustang to the explorer 4.6l. The tork tech kit is designed to work with the mustang's. you have to eliminate a pully that comes with the kit and cut a pully mount off the expolrer cover. then route the belt like I have in the pics.
2. The new belt route runs right in front of where the oil filter is supposed to go. get a remote mount filter kit and mount it somewhere safe.
3. Trick flow heads do not have bolt mouting holes for the explorer power steering pump. The pump on the explorer is higher up the TC than the Mustang. either make a braket,just use 2 bolts,or drill and tap the heads.
4.knock sesor bosses. The explorer block has 2 knock sensor bosses under the intake these need to be cut off and the sensors tuned out. or placed somewhere else.
5.top bolt on belt tenisioner needs to be ground down or left out.
I am sure there is more but I am not there yet lol.
Wills05xlt4x4
Ashland Va
2005 Xlt 4x4
If I'm not mistaken, you can move the knock sensors to the heads...
HiImBrian
St. Petersburg, Florida
2003 Explorer Eddie Bauer
You can move the knock sensors to the back if the heads. I just did it last weekend. The left side will be closer to the middle and the right side will be closer to the fender. The wires for them are different lengths so you'll have to switch sides for them to reach.
zerodevil
Anchorage, AK
2008 White Limited V8
I find myself inspired. I am looking at doing almost the same thing you are, I want to stroke to 5.0, upgrade to an 8 bolt crank, TFS heads, Injectors, and the same cams you have. I had been considering a Kenne bell or a custom front mount turbo kit, but the cost on that supercharger kit is somthing to consider when we are talking about thousands of dollars worth of savings. I was hoping to net a stable 400 - 450 at the wheels on about 6 - 9 PSI on 91+ octane pump gas. Have you done any upgrades to your fuel system other than the injectors? I have been wondering for years what the stock explorer system can support.
Aaron95cobrar
stealth 340 pump and thats it for the fuel system. right now I am in the middle of rebuilding the transmission.
DallasGT01
DALLAS, TEXAS
2004 Explorer EB 4X4
that GS340 will hold some power... on a BAP they hold 700whp on DSMs and 4cyl turbo cars... those heads are alittle over kill i think for this build.. did you port the blower and fill silencer holes??
2Trux
Albuquerque, NM
2005 Limited V8 4X4
It will be interesting to see how well the belt will do since the rerouting causes it to only contact about 1/3 of the crank pully. When the A/C goes on there will be a lot of drag on that belt.
