rickvo
- January 10, 2006
- Rochester,NY
- 1998 XLT
Is a A4LD converter the same as a 5R55E??
First of all I have a 1998 Ex with the 5R55E and I have the dreaded PO741 code that comes and goes. I tried the TCC solenoid replacement to no avail. Code came back and I have the torque converter rattle when stopped at idle in any gear. Rattle goes away in park or neutral. The Trans shifts great into all gears but I have no converter lockup ..that is when the OD light is flashing, it come and goes.
Anyway.. I am thinking I should R&R the converter ASAP. What do you think?
Questions....
1. Is a A4LD converter the same as a 5R55E?? when I look the the converter up at Advance Auto and at the Auto Zone by application it says the converter is for a A4LD trans. I called them but The guy on the phone doen't know anything about it so I need help here.
2. Is it ok to buy a converter from the local parts store?
3. Should I be replacing anything else like the trans pump seal..(it dont leak a drop now) or maybe a bushing? Of course new oil and filter is a must.
Thanks for your time!
Questions....
