Torque Converter Rattle? | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership! If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
reansor
Baltimore, MD
2003 Mercury Mountaineer
Hey, I've read plenty about the 4.6L 5R55S "Dreaded Torque Converter Rattle," and I've fairly certain I've had it for a couple years and several thousand miles. Truck drives great and trans shifts great, but I hear this rattle only when in gear at idle. It clears up as soon as I barely touch the gas. Here's a dropbox link with the audio of it: https://www.dropbox.com/s/v3qzncdgqjekbim/torque conv rattle.3gp?dl=0
Someone please take a listen and confirm. Thanks!
Holiday Special! Join the Elite Explorers $20 for 2 years! Gets rid of the ads!
reansor
Baltimore, MD
Fyi, it sounds more extreme than it does from outside or inside the truck. I recorded this with the phone real close to the bell housing. And, no, it's definitely not the catalytic converters--I just replaced them a couple months ago for a different reason and it didn't change a thing on the noise.
ROBinGa
Ga
2003 Explorer XLT 4x4 4.6
I can't open the file. But our 03 has had some symptoms as you describe for as long as I remember and at least 75-80,000 miles. Just sounds annoying at park and sitting at stop lights. Otherwise operates just fine
reansor
Baltimore, MD
reansor
Baltimore, MD
Yeah, I just tested the link and it made me download it to be able to play it. At one time I thought maybe it was one of the torque converter nuts rattling around in the bellhousing, but it's not. Like I said, the sound goes away as soon as I barely touch the gas.
imp
Location
West-Central AZ along the Colorado River
59 Ranchero F250 D'Line
@reansor
Could be coming from the flex plate, maybe, but if noise continues without increasing, it may be easiest to live with it. Torque Converters by their very construction and nature are quite unlikely to make a rattling sound, and continue to do so for a long time. imp
reansor
Baltimore, MD
I dunno. There are a ton of posts on here regarding the issue. Apparently it was some kind of design flaw, but not a durability issue. I just finally had a chance to actually record the noise and post it.
imp
Location
@reansor
If it is actually a metallic-sounding rattle, almost certain to rule out rear axle friction plate noise. imp
Number4
"I'm counting to 3, then I'm getting your dad."
Woodstock, GA
04 Ford Explorer 4.6l
There was an Aussie that posted about something going out in his torque converter. Bearing? Basically causing him to lose lock-up. He dropped the pan and the filter was covered in shavings. Truck still ran. I'm banking on this being the issue.
Mine did the same, noise has since gone away. I need to drop the pan and see if the filter is covered in shavings too. Biggest concern is fluid still being able to circulate. Mine still drives but is beginning to show signs of trouble. With 190k, I've not wanted to throw on a new torq conv as was done. Kinda of just waiting for it to fail.
reansor
Baltimore, MD
I changed my filter and fluid not long ago and it was all very clean. I got that term, "Dreaded torque converter rattle" from some of the many posts on this site about it. My trans shifts and performs fine, and many people with the rattle have said that they've gone as many as 100,000 without a problem.
MyExplorer03v8Lim
2003 Explorer 4.6L
Just want to piggy back onto this. My 4.6 '03 makes a pretty loud metallic scraping sound during acceleration, and the sound only cuts out at around 50mph, I assume this is when the truck hits OD/ TC locks up. I have a feeling it's the TC, but it's not a rattling noise so much as a scraping noise. Anyone familiar with this type of noise?
Hugh Janus
Location
Land of Oz
boise, idaho
2002 XLT Explorer
TIming chains.
reansor
Baltimore, MD
TIming chains.
SOLUTION?: No, I know it's not timing chains because I put a stethoscope on those also. It's definitely coming from the bellhousing. Just an hour ago I let two guys from a very reputable transmission shop take a quick glance and, contrary to people calling it "The Dreaded Torque Converter Rattle," he said it's almost certainly microscopic cracks in the flexplate and that my best bet is to just drive it unless it gets worse.
MyExplorer03v8Lim
2003 Explorer 4.6L
TIming chains.
Yeah. Just got it back from the shop. Tech confirmed timing chains. Good call!
Have you tackled this job before? Guessing from your confident and concise reply that you know all about it.
It'll be my first one but I'm pretty sure I'll be doing it myself.
reansor
Baltimore, MD
I've rebuilt plenty of small block Ford engines but I've never had to dig too deep into a ohc engine. I've researched the timing chains for the 4.6 some because I know I'll need them eventually. It looks like a pain in the ass but it's definitely something I would do myself because I can only try to guess how much a shop would charge--LOTS!
Get the kit with the 2 Chainz, guides, tensioners, and maybe the cam sprockets. You'll need the cam position holders too, but you might be able to get those on the loaner program from AutoZone or advance. Otherwise they're not too expensive from Amazon. Get a Chilton or Hayes book too, and read up on it so you know what you're doing before you start pulling it apart.
reansor
Baltimore, MD
reansor
Baltimore, MD
BTW, I didn't mean 2 Chainz the rapper, obviously, but Google Voice typing thought so.☺
Hugh Janus
Location
Land of Oz
boise, idaho
2002 XLT Explorer
Radiator and PS pump are the tough parts of the job. You dont need special tools for holding cams.
MyExplorer03v8Lim
2003 Explorer 4.6L
Is just holding the cams with vice grips fine? Do I need any special tools to get pulleys off?
