BlueX
- June 7, 2013
- 2002 Explorer xlt 4x4
Since I've had this '02 explorer (about a year now) it's been making a rattling noise. Checked the heat shields and none seem loose. Thought it could have been the idler arm or something so I replaced the idler arm, alternator, idler pulley and serpentine belt...still rattles.
The rattling occurs at idle randomly, but without fail always rattles right around 2200rpm and above. Something I thought was mind blowing however was that once winter rolled around, instead of rattling the noise would be a whining sound after the truck had sat over night in 30 degree or below temps. After the truck warmed up however, the noise would return back to a rattle!!?? I read somewhere that this could possibly be due to a failing torque converter. Any ideas of what it could be?
P.S.~ I took the truck to the Ford dealership and they said I had to replace my front upper ball joints (which I've done since) and replace my rear hub assembly before they could diagnose the sound. What kind of BS is that!!
Thanks for any input!
