Torque converter to flywheel/flexplate bolt alignment | Ford Explorer - Ford Ranger Forums - Serious Explorations
Xylene
1998 XLT V8
I just rebuilt my 302 5.0l engine and have a question about the torque converter to flywheel/flexplate (I can't remember which one is which for an automatic) bolts. Does it matter what bolt goes where? There are 4 of them, I marked the bolt to the flywheel before removing it, but didn't check when I reinstalled. Will this lead to isssues?
fastpakr
Roanoke, VA
99 4wd - 5.0/4R70W/BW4406
No worries.
C420sailor
Long Island, NY
98 XLT SOHC, 99 EB 5.0L
They aren’t balanced as a unit.
It was advised to me to use new nuts with a dab of blue loctite. Not sure if it is necessary, but I haven’t lost one yet
Xylene
1998 XLT V8
I have been on the hunt for new flanged nuts grade 8 (it looks like what was on it) but I haven't been able to find any
fastpakr
Roanoke, VA
I bought a set on eBay as i recall.
C420sailor
Long Island, NY
I believe this is correct, double check. I used Mr Gasket ones on my 5R55E but I don’t know if they’re compatible with the 4R70W—these should be
The nuts on my 5R55E are metal locking nuts, and I think these are too. They look very similar to normal flange nuts, but they are special
donalds
Location
Stem
Nc
1999 ford explorer sohc
This is where I find stuff like this McMaster-Carr <<catalog
Nuts>> unless you have a part number Then buy that
C420sailor
Long Island, NY
I love McMaster Carr, just wish they had smaller sizes. When I need 4 nuts and they sell batches of 100 lol
donalds
Location
Stem
Nc
Yep fastest delivery period
Lol if you can't find what your looking for in their catalog then look again lol
I don't mind the extra
Needles to say I have collected a bit of hardware over the years
All stored in Christmas cookies tin containers
fastpakr
Roanoke, VA
The Mr Gasket p/n should be 6717. 3/8-24 flange nuts.
Turdle
The Lowrider is a little higher
Staff member
Moderator
Humboldt, KS
2000 Mounty
Look closely at the factory nuts. They are kinda "smashed" looking, the threaded hole is slightly ovaled to stake the nut in place once torqued to spec. Reuse em if they arent rounded off.
Xylene
1998 XLT V8
I was able to reuse 3 of the 4. I wasn't able to find an exact replacement for the 4th so I ended up buying a self lock flange nut from Ace Hardware. If this isn't a good idea I can order a set online (no local stores carry them). I was trying to finish up my project this week, but if I need new bolts I can wait for them to come in the mail. I would rather do it right, then have to deal with it later.
