Torque Monster Headers in way of Camber/Castor Bolt!
Boggl
San Diego, CA
97' XLT AWD V8
Hi,
Anyone else have this issue with the passenger side "front" upper control arm bolt unable to be removed?
Trying to do control arms bushings and now stuck - ugh
Join the Elite Explorers for $20. Gets rid of the ads!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
Dono
347 V8 Limited turbo
Winnipeg, Manitoba
00 Limited V8
wow,
Looks like doing UCA's just became way more difficult.
mounty71
It's green, not gray.
Oakland, CA
'00 Mountaineer
Can you remove the nut on the bottom of the motor mount through the hole in the frame, and then lift the motor enough to remove it? Or cut the bolt off then reinstall a new one from the other direction?
MAS Tequila
Boca Raton FL
2000 Mounty 4WD 5.0
If that's the welded stock bolt, it looks like it.
Cut it and get a couple sets of MOOG adjustable camber bolts.
They WILL go in and out easier, they're not welded together and are lot easier to use.
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
^^^^^ what he said. Cut it out and gets a set of moog bolts. They will go back in and out with those headers.
That's not a stock adjuster but the stock adjuster looks like it would give you the same issue.
Boggl
San Diego, CA
97' XLT AWD V8
Carefully squeezed a Dremel in with a EZ lock cutting wheel and trimmed off just enough of the threads to get the bolt out. Cleaned it up on the grinder and chased the threads.
Bushings replaced by getting creative with a ball joint press and bench vise.
This is a two piece arm and dont want to go with a one piece so replacing the bushings
Back on the road !! Thanks everyone.
M Torque monster headers horsepower Modified 1995-2001 Explorers 8
Dono Torque Monster Headers with Bob back Modified 1995-2001 Explorers 10
A 5.0 Headers problems with Torque Monster and OBX Modified 1995-2001 Explorers 2
S Torque Monster Headers Modified 1995-2001 Explorers 6
A Torque monster headers leaking collector Modified 1995-2001 Explorers 7
B Torque Monster headers Modified 1995-2001 Explorers 11
9 Torque Monster headers making comeback ??? Modified 1995-2001 Explorers 91
A 5.0 Torque Monster Headers on eBay Modified 1995-2001 Explorers 5
P Torque monster headers Modified 1995-2001 Explorers 8
S Torque Monster Headers WTB Modified 1995-2001 Explorers 0
M Rusty Torque Monster Headers Modified 1995-2001 Explorers 20
B Torque Monster headers install problems Modified 1995-2001 Explorers 42
B Are 5.0/Torque Monster Headers still made? Modified 1995-2001 Explorers 8
R Do Torque Monster Headers increase the engine sound much? Modified 1995-2001 Explorers 1
S TORQUE MONSTER Headers GROUP BUY Modified 1995-2001 Explorers 652
X Wanted Torque Monster Headers? Modified 1995-2001 Explorers 2
M anyone know whats up with torque monster headers Modified 1995-2001 Explorers 9
P Torque Monster Headers installed CODE PO300 Modified 1995-2001 Explorers 10
1 torque monster headers.... Modified 1995-2001 Explorers 17
D Torque Monster Headers and 1" Intake Heat Spacer Installed Modified 1995-2001 Explorers 0
V Torque Monster Headers are awesome Modified 1995-2001 Explorers 33
S Getting Torque Monster Headers, what else should I do? Modified 1995-2001 Explorers 3
C Installed Torque Monster headers and spacer, now I have a lopeing or chugging idle Modified 1995-2001 Explorers 2
Hyper26414 Torque monster headers vs. Ford racing headers Modified 1995-2001 Explorers 5
MountaineerGreen Torque Monster Headers Install Write-up and Review Modified 1995-2001 Explorers 364
S guys with torque monster headers ? Modified 1995-2001 Explorers 5
W Torque Monster Headers Ordered!! Modified 1995-2001 Explorers 17
S Nice bit on Torque Monster Headers on Trucks! Modified 1995-2001 Explorers 1
B Torque Monster Headers First Impressions Modified 1995-2001 Explorers 3
LiKuiD So my Torque Monster headers are installed... Modified 1995-2001 Explorers 19
S Torque monster help Modified 1995-2001 Explorers 1
1 Christmas Came Early... Torque Monster!!! Modified 1995-2001 Explorers 4
Dono torque monster install gone bad Modified 1995-2001 Explorers 34
P torque monster header install dvd link Modified 1995-2001 Explorers 0
P torque monster install gone bad.. Modified 1995-2001 Explorers 19
M (HELP!) Torque Monster Header custom EGR pipe Modified 1995-2001 Explorers 4
P Torque Monster header availability teaser... Modified 1995-2001 Explorers 33
C torque monster header not running right Modified 1995-2001 Explorers 9
celly Torque Monster Header (TMH) Gasket Replacement-Pointers needed Modified 1995-2001 Explorers 94
Cobraguy Torque Monster Header Installation Tip Modified 1995-2001 Explorers 1
1 Torque Monster and front cats? Modified 1995-2001 Explorers 12
Mutineer Mutineer Torque Monster Install Modified 1995-2001 Explorers 16
W 1 of 2 Torque Monster header(s) install Modified 1995-2001 Explorers 2
S torque monster header owners ??? Modified 1995-2001 Explorers 8
T 98 explorer suspension torque spec. Modified 1995-2001 Explorers 4
S Torque Monsters Modified 1995-2001 Explorers 12
K torque converter not unlocking. Modified 1995-2001 Explorers 2
bigred4x4 torque converter solenoid Modified 1995-2001 Explorers 4
M Looking for Torque Mods Modified 1995-2001 Explorers 4
C 1999 explorer sohc torque converter lock up Modified 1995-2001 Explorers 13
Similar threads
