Torsion Bar 101, Everything you Need to look for!
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
if i want to lift it do i loosen or tighten the bolts?
You can easily lower the truck by climbing under it and loosening the bolts.
To raise the height, always first lift the truck off of the ground. There is a ton of pressure on those bolts, avoid tightening them with the truck on the ground.
joshpatzer2
fort wayne IN
1999 ford explorer awd
when you do a TT lift to the front of your explorer, you will need to get an alignment done and you may be told you need to buy the eccentric nuts so your camber can be put back to spec. some explorers had the eccentrics from the factory and some dont. the eccentric nut allows the alignment tech to adjust the distance of the upper ball joint to the frame so that the camber angle of the front tires is right. i did about "2 inches in the front of mine, along with lift shackles and i can clear 265/75r16 BF Goodrich AT's. I did have to get the eccentric nuts (i bought one for each of the four bolts just to have the flexibility and adjust-ability in the future), but they are only like $20 each so well worth saving your $200+ tires from excessive uneven wear.
wollimann
Europe (Germany)
1997 4.0 sohc xlt
Explorer 97 camber caster
Hello :usa:
I am a desperate guy from europe, cause two alignment guys (different shops) can't get the correct camber alignment.
Also have longer shakles and the torsion bars are liftet up for about 1,5".
The camber was a lttle bit negativ after lifting, but not too bad.
I ordered the MOOG one piece design upper control arms for both sides and the MOOG camber/caster kit, cause the bushings were worn out. OK, replaced the parts by myself and before i measured the alignment (positions of the original eccentric washers) of the upper control arms.
After changing the arms with new camber/caster kit (steering wheel ok, no brake fading) drove to the tire-shop for alignment, but the guy couln't fix it.
He attempt everything for 2 hours but he throw's the towl.
At home i verified if it was my fault, but i wash my hands in responsibility.
The next tire-shop alignment guy couldn't fix it neither, but he had some ideas. The elongated wholes at the frame for the control arm bolts are maybe not long enough. So the control arm couldn't get/came out enough for a proper camber.
Now i am searching for some missing degrees for my camber, the caster is ok they said.
Did anybody had similar problems, maybe an approch?
The upper control arm has the "knuckle in spindel" design, so there are no accentric alignment bushings available, like the older Ex/Ranger has. A replacement eccentric MOOG joint would be the solution, but i found nothing.
Found some eccentric control arm bushings, but they don't fit for the Explorer control arms :mad:
If anybody could help me to get a little step forward, i would be very happy.
thanks
Wolfgang
BigZ97ex
New Jersey
1997 Ford Explorer XLT
Is there anyway i can lift the front of my truck without a torsion twist. i have a 97 xlt awd and i put warrior shackles on the back but now the rear is an 1 1/2 - 2 inches higher then the front. Can i just buy a body lift but just for the front, like a leveling kit. I dont want to have to buy new torsion bars if i mess it up.
swshawaii
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
You can't damage the torsion bars by tightening the bolts. If you lift higher than 2 inches, CV half shaft binding is very likely. Any time ride height is altered, alignment is usually required, and camber kits installed depending on the lift distance and camber angles. Highly recommend marking the bolt threads before lifting, should you decide to return to the previous height. Doing a body lift only on the front would be awkward, dangerous, and literally half assed. :mattmoon:
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
Lift the front off of the ground before cranking the torsion adjustment bolts upward. There is a ton of pressure there.
Adjust the front by what you want, and end by making the front LCA mount bolts the same height. Those should not be different left versus right, regardless of the fender measurements.
I have had mine lowered by around 2.5" for 11 years. One axle was replaced just before lowering it, and it's still there unhurt, with 104k miles on it lowered. The other axle I bought about three years later than the other one, and I had a boot rip on it. That one I got warranted, but it looked fine also.
You can have the front axles survive well at around 2-3" from level.
lensey
Checotah, Oklahoma
1997 ford explorer
What is your final ride height after the tt? I have a 97 sport4x4 and already has shackles.
97cherbal
Puyallup,Wa.
1998 Ford Explorer
war 153 from 4wd parts $110
97cherbal
Puyallup,Wa.
1998 Ford Explorer
keep or disconnect sway bars & what size bolt is needed for it to be 1" longer
OK just read all 26 pages & three questions was never brought up or not answered. I have a 98 EXP xlt 4.0 SOHC 4wd it has the (B) Torsion Bars
1) If a AAL & shackle kit & TT is done for a 1"-3" lift is it best to disconnect the sway bars to gain addition suspension movement?
2) The small anti wrap axle shock connected to rear diff. Should that be replaced with one that's 2"-3" longer or just removed & not worried about?
3) Around pg 10?? a guy asked whats the length of the TT bolt. He was viewed more then 50x but never got a reply.
So whats the stock TT bolt dimensions?
Lets say for EXAMPLE: its a 10mm x 50mm x 1.25 Thread Pitch 25.4 mm is conversion for 1".
If I wanted a bolt that's 1" longer does 10mm x 75mm x 1.25 TP sound about right.
A bit of info for doing a TT or basic Front End Alignment at home either it be on gravel, grass or concrete., but flat surface area.
Grab 4 pieces of 3/16" -1/4" steel plate about 12" x 24" & 4 pcs of 4' x 1/4" hard wood dowel stock & cut them into 12" sections this will give you 16 pcs.
Set 2 pcs of steel plate in front of front tires with 24" going left to right & centered in the tires width. Take 8 pcs of 12" cut dowels & placed evenly apart across the 24" section & then take a second piece of steel plate & lay over dowels. Then slowly drive forward until front tires are centered in the 12" width.
You now have a sliding platform to allow the tires to slide inward or outward while doing a TT with out lifting vehicle. This should work for ANY vehicle up to a 1 tn vehicle for doing a basic FEA as well
MGRocker
02 Ford Explorer XLS
So I have a 02 explorer xls 4x4 and I dont see torsion bars. So how would I level it? And how much left would I need?
BUXTER
SUMMERVILLE
2001 MERC MOUNTY 5.0 AWD
Torrsion Bar 101, Everything you Need to look for!
SO>>> to drop Front only I take it u just loosen the Torsion bar Adjuster Bolt a couple turns ? - There's no "lock" on it____?
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
You can lower it that way easily with a ratchet and 15mm I think socket. But to raise it that way, the front tires need to be off the ground. There's a ton of pressure on those adjustment bolts.
Don't change the height unless you are about to get an alignment, that alters the camber as it changes. So do it right before new tires or an alignment, when rebuilding the suspension etc.
98Hooptie
Raleigh NC
98 Sport 2dr
Its 13mm or 1/2" SAE socket size. I literally raised mine yesterday. I actually bracket race my Sport on the dragstrip so I wanted a bit of rise on the front and to get about -.5" camber so I gained both in less than 10mins worth of work with a few turns of the ratchet :)
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
13mm, right, it's been a while. I have drop keys in one of my trucks, and a pair yet to install. It's easy to lift them some, to get an acceptable alignment when dropping it is hard.
Lazerskull
Loomis, CA
1997, Explorer, XLT
Why do they sell torsion keys online? Is this because when they wear out the torsion bar slips? Do I have to buy them or can I just continue using my stock keys? BTW. I just want a 1.75" = 2" lift.
Mbrooks420
High Voltage.
1998 Mountaineer AWD
The aftermarket keys add lift, I believe. You shouldn’t need them.
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
The aftermarket keys come in a couple of various heights, the torsion bar hole is clocked differently. The later Rangers and Sport Tracs use keys that add height in the same way.
All of the keys have a height range they can achieve, so the stock keys you have most likely can be adjusted up at least 2" more.
