Torsion Bars Maxed Out - Buy New Bolt?? | Ford Explorer - Ford Ranger Forums - Serious Explorations
macker123
victoria, bc
97 Explorer Sport 4.0 OHV
I just finished installing my shackles on my 97 Sport. Turns out I had to max out my torsion bars to get an even height.
I was wanting to buy some 4-door leafs and then add a leaf, but of course my front is maxed out.
I am not going to worry about it for now if I have to buy spindles as I am already spending to much on the truck.
Can I just buy longer bolts? If so can somebody tell me what size. I have the 97 Sport so I presume all Sports have "D" rated bars.
section525
sextion525
Moderator Emeritus
Red Bluff, Ca
1975 Ford Bronco 4x4
Yes you can buy longer bolts. I did the same thing back when I was 2WD. Search the site, because I know the size bolts you need are on here somewhere. :D
section525
sextion525
Moderator Emeritus
Red Bluff, Ca
You talked me into finding it for you... M12X1.75X90mm
section525
sextion525
Moderator Emeritus
Red Bluff, Ca
That should be your stock size. So you should get some a little longer. Also, before you put them in it is a good idea to ground the tip to a nice round.
mach1460
laramie Wyoming
93' limited
just in case u didnt know ....
when your removing torsion bars, use making tape and mark the sides as they come out front/rear driver/pass side if they are installed the wrong way they will snap within a few blocks , they are only made to twist one way if they are twisted the other way they break, i reccomend new ones if u have the means but the old ones work fine
macker123
victoria, bc
I don't have to remove the bars to install new bolts?? I just unscrew the bolt and screw the new one in, correct?
section525
sextion525
Moderator Emeritus
Red Bluff, Ca
Right! :D
sk1er17
My "Jeep Thing" itches...
NJ
'98 Sport
If you still have the monoleaf on the rear you might not need those new bolts... I have a 98 and i did the TT/Shackle and because of the monoleaf my truck sagged worse than before i got the shackles. I recently put on the 4 door springs at it evened it out... Im ordering a Double AAL from pro-comp so i get 2 more inches in the back... when everything settles i should have 1-1.5inches higher in the rear than the front.
If you want the double AAL too- you can call 4wheelparts... they dont stock it but i called pro-comp and the part # is 13135.
Doug
Moderator Emeritus
Sykesville, MD
You can get procomp add a leafs from summit racing. I just ordered some last night and they where 35 dollars with shipping.
