Torsion twist damage? | Ford Explorer - Ford Ranger Forums - Serious Explorations
BigT
Edmonton, Alberta, Canada
'98 Sport
I'm thinking about putting shackles and a TT lift on my 98 sport, but I was talking to a guy at a off-road shop and he was saying that the added angle of the a-arms could cause the ball joints to fail and that there would be added wear on the cv joints, even going with just a max 2" lift. Anyone have any info or experience with damage to the front end due to the twist?
Ak LTD Xplorer
Anchorage Alaska
1996 LIMITED OFF ROAD 4X4
you shouldent max out the TT's it can be bad..i was going to do the TT lift but have ne need with my ARC set-up like it is..
Alec
Elite Moderator
Moderator Emeritus
Houston, Texas
2008 JK
Welcome!
As long as you keep it under 2" of TT you're fine.
JDraper
Somewhat Functional
Moderator Emeritus
McVeytown, PA
'18 XLT
As Alec said, keep it under 2" and you'll be fine. I've had mine in for almost 40k now. Yes my ball joints gave up a little early, but that is a problem for most Explorers, lifted or not. Ford uses crappy non greasable ball joints.
