Leucoandro
- April 2, 2002
- Jonesboro, AR
- 1997 Explorer Sport
Torsion Twist, Warrior Shackles and leaf bundles, a Fresh Look
Hello Everyone I just thought that I would do a fresh Thread on suspension to consolidate and get a couple of my questions answered. Most will deal with my Experiance with a 97 Explorer Sport.
First We will Talk about General Lifting. Start by Doing a TT Lift. It is simpler and harder than it sounds.
Simple
1) on a flat surface measure the distance between the ground and fender wall on both sides of the front of your truck. Remember these numbers. and add at max 2" as your desired lift. and wd 40 your TT Bolts
2) on the center of your front end jack it up, make sure that both sides ballance and make sure that both wheels are off the ground and resting at there farthest down possision.
3)tighten your TT bolts equally on both sides and let the front end down. measure both sides and repeat until you have the desired lift.
For the rear end simply add a set of warrior 153 shackles, it is fairly simple and the shackles come with instructions. (tip, you might want to pick up about 4 washeres that will fit the bolts for the warrior shackles incase you have any slack you need to take up in them.)
Next (and this is my question part) stronger suspension.)
On my front end I have F rated T Bars. This ride seems a little light weight for me and I was wanting to get a stiffer ride, but not too uncomfortable. So I was thinking about going to the D rates T Bars for the front end. Will that make the ride stiff enough? Should I go to the B T Bars. Also I believe that my T bars in the front might be off. I have both sides cranked up the same, but my left side always sits about 1/2 to 3/4 inch lower. even when I let the right side down and leave the left alone, the left side still is lower. If I were to keep my current T Bars should I adjust my left side?
In addition
I have the 97 explorer sport with the Mono Spring in the rear, and I hate it. I am wanting to go to the 3 leaf bundle with a O/L spring. I found a bundle at a Junk yard for $25 per side. Now the thing is it is from a 97 explorer 4 door. I think I read that I can change these out, although details are scetchy. Would there be any serious mods I would have to do to put the bundle from the explorer 4 door under my truck? What all parts do I need to get from the yard? Do I just need the leaf spring bundle, or do I need I need additional parts, IE different U bolts, or different shock mount? Has anyone done these mods before and can give me any details of things I might encounter?
Final Q
If I change my T bar to a D rated do I have to use one from a 2 door, or am I able to use one from a 4 door also? I read in one thread that I have to use one from a 2 door and in another I read that I can use one from a 4 door. If I go from F Rated T bar to D rated, how much firmer will that make my ride? How hard is it to change T bars?
Here is my plan. If the T bars and Rear Leaf are interchangable between the 4 door and 2 door explorers. Then I will go down to the Junk yard and find a 4 door explorer with D Rated T bars, then I will Take the T bars and leaf bundle off (I will asume that the front suspension and rear suspension match) and Install them on my truck to give it a firmer ride with the lift I already have from the warrior shackles and redoing the TT lift. Does this sound like a Workable plan without too much work? (I just added a block on the rear end of my friends Yucon [gasp] and I am not planning on the rear leaf bundle swap on the explorer to be much harder than adding a that blasted block, Especially because he already had the rear end totally removed on his yucon before I could get there to help, he made it a little harder than it had to be) Anyways Any info would be appriciated
Thanks
Charles
Simple
In addition
Final Q
Thanks
Charles
