I just bought a pop-up trailer (1700 lbs dry weight, probably 2200 - 2400 loaded with gear). Then I bought a 2003 SportTrac to tow it. It came with a receiver hitch on it. I towed it recently (unloaded to service center to get some work done on trailer) on fairly flat ground and then on the way home, through some hills. On flat ground with overdrive off it ran around 3200 RPM's and really seemed like it wanted to go to overdrive. I turned OD on and it towed fine (2100 RPM’s), only once slipping down into 4th on a slight incline. Through the hills I kept the OD off and it still ran around 3200 RPM but had more power pulling up the hills. My question is can I tow in OD on flat ground?
