Towing?
How are your rear leaf springs? good firm/add-a-leaf helps support esp. if you've put elongated shackles.
Rear sway bar & bushings condition? stable the back end.
what rear shocks? I have F150 heavy duty rated rear shocks.
Use a HITCH.
Tires? correct type, aired up, in good condition. - I have 10ply LT235/85R16 and they roll smooothly.
Balance the load- a trailer with improper balanced load from tongue/over axle can really effect control, traction, stability(sway)
Does the trailer have power assisted brakes? It's not that the Ex can stop, but will it safely when someone pulls out in front of you?
Check trailer tire, rim, lug nuts, load securement
I have/have had motorcycle, car/truck POV, CDL driving dumptruck & semi, small craft naval training, & want to become a pilot
- I don't mean any of this in gloating or arrogance, but for assurance. Respond if you have questions of towing.
you tube or google video search for hauling load and trailers. 98% will be fine. 1% may be in learning error, 1% other idiots
Have a blast with the boat
