Towing about 3200 lbs with the 2" ball on bumper, bad idea?
protomind
94 Limited Edition
(delete please)Towing about 3200 lbs with the 2" ball on bumper
I plan on towing a 3200lb gross weight loaded trailer to Edison NJ from Detroit, this move is costing me alot of money and installing a frame mounted trailer hitch just may break the bank. Can I get away with using the bumper and not messing anything up at all? Any towing tips other then the obvious 'take it easy'.
JDraper
Somewhat Functional
Moderator Emeritus
McVeytown, PA
'18 XLT
Yep...bad idea. Your bumper is rated as a class II device for 3500 lbs, but it's not ideal. Unless you get lucky, and the trailer tongue is exactly at the correct height, your trailer will be tilted and this can lead to instability. For the distance you're going, spend the $125 on a Class III hitch (or find a used one cheaper) and be safe.
Tips...
-Leave a LOT of braking room between you and the vehicle in front of you.
-Manually take the vehicle out of overdrive on uphills to protect the transmission.
-Put a good transmission cooler on the vehicle.
-Get the trailer loading correct. Make sure there is positive weight on the tongue (between 100-200 lbs at the ball is good).
-Make sure the trailer tires are properly inflated before loading it. They may look fine when it's sitting empty, but may need to be inflated to properly carry a load.
-Make sure your safety chains are hooked up properly
-Make sure the trailer is properly seated on the ball and that the ball locking lever is locked down (put a pin or lock through the hole).
-Stop every so often and check the trailer. Make sure the bearings aren't overheating and the tires are still fully inflated.
Mbrooks420
High Voltage.
EF Vendor
1998 Mountaineer AWD
With your 3.27's it's going to be a dog. Do you have a trans cooler at all? Is your truck rusty? That's a lot of weight, but you should technically be within range. Load the trailer smart, with the weight distributed. The general consensus you will get here is "you need a hitch". I wouldn't say it's a good idea, but not because of the bumper, but because of your gears, and transmission. You could live with a bent bumper, or replace it for under 200, get a hitch for 150, but if you smoke your transmission it will cost you a lot more.
C Towing: 2019 V6 (Limited) or 2019 Ecoboost V6 (Sport)? Tow Rig Forum 12
I Towing Mirrors for 2015 Explorer? Tow Rig Forum 0
traveler Towing Jargon Tow Rig Forum 1
2 Anybody towing a long trailer? Tow Rig Forum 1
N 2012 Police AWD 3.7 or a 2003 Sport Trac for towing Tow Rig Forum 11
M 2010 Explorer 4.0 v6 towing capacity? 5205lb? Tow Rig Forum 6
A Towing with a 2004 V8. Am I doing this right? Tow Rig Forum 15
D Towing a vehicle - 2015 with factory class III Hitch Tow Rig Forum 10
J 2018 Explorer Sport - Towing a Travel Trailer Tow Rig Forum 47
R Newbie Question: Towing a Popup Camper Tow Rig Forum 33
O Newbie question | RV Trailer towing Tow Rig Forum 2
C Towing Camper w/ Explorer Sport V6 AWD Tow Rig Forum 19
T 2017 reverse sensor when towing Tow Rig Forum 5
L Towing with an 04 Sport trac Tow Rig Forum 1
K Towing Limit.... Tow Rig Forum 16
4 Towing issues with lowered 5th gen Explorer? Tow Rig Forum 3
J Towing Trailer Length for an '07 Explorer Tow Rig Forum 4
B 4th Gen Towing upgrad parts help Tow Rig Forum 11
E 2014/2015 Towing Capacity Tow Rig Forum 2
P 2008 Explorer Class 2 towing HEIGHT problem Tow Rig Forum 3
L Dealer Installed Class III Towing package Tow Rig Forum 1
SavaX beefing up rear suspension for towing Tow Rig Forum 4
K Towing with a 2006 XLT 4.0L Tow Rig Forum 15
L 2014 Explorer Sport and Boat Towing Tow Rig Forum 5
V Towing tagalong camperv Tow Rig Forum 2
E '03 Explorer - first time towing! Tow Rig Forum 3
B 2007 Mountaineer towing travel trailer Tow Rig Forum 13
B Towing a Bronco II Tow Rig Forum 7
R V6 STA isn't so bad at towing after all Tow Rig Forum 1
M towing lights Tow Rig Forum 1
S Towing a 2011 Ranger Sport 2 wheel drive Tow Rig Forum 0
C 2015 Explorer towing Tow Rig Forum 3
C increase towing capacity Tow Rig Forum 10
C Towing capacity with larger tires? Tow Rig Forum 2
L Towing into Yellowstone Tow Rig Forum 1
M Camp trailer weight towing question! Tow Rig Forum 7
U 2009 Explorer suspension upgrade for towing? Tow Rig Forum 8
X Towing with 2011 5 th generation Explorer Tow Rig Forum 15
O Towing a Firebird with 97 XLT 5.0 AWD -- looking for advice Tow Rig Forum 10
B heating up while towing? Tow Rig Forum 7
I towing pop-up camper and bikes Tow Rig Forum 3
B Towing Help please Tow Rig Forum 2
C Downsized from Expedition worried about towing Tow Rig Forum 7
N Towing for dummies and alternatives to Uhaul trailers? Tow Rig Forum 4
T Official Ford Towing Guides Tow Rig Forum 0
B Towing...right on the line Tow Rig Forum 3
M towing capacity upgrades? Tow Rig Forum 0
M towing capacity upgrades? Tow Rig Forum 1
Gatorblazer Towing a piano with a 3rd gen Tow Rig Forum 6
jprentice94 92 towing Tow Rig Forum 0
Similar threads
