I'm away from my Explorer at school for the time being, so I can't get to an owners manual or anything. But I'm hoping I can get some help with this. I've searched the forums, but only come up with posts a bit more specific than I'm looking for.
I'm looking into buying an ATV. The weight, as I've been seeing (sport ATV) is around 400-500 lbs. Looking at trailers, I guess the weight for a standard one to carry an ATV is also in that range (again, I'm just starting to look into it). So that's about 1000 pounds. I have a class II hitch on my 2004. Will I need to do anything special for this, or should I be all set to a) Get a ball for the hitch, b) Buy/Rent a trailer, and c) Tow the ATV? For larger things, I've seen people recommend getting a transmission cooler and having a temperature gauge, but will I need this for towing about 1000 lb? What if I upped it by adding another ATV, making it around 1500 lb? Thanks for any info you can give me.
