Towing trans damage
druppel
Wildomar CA
96 xlt
I have a 93 4wd auto explorer which I towed in neutral for about 400 miles about 6 times behind my motor home. I just read you can fry the trans if you don't drop the rear drive shaft. How do I know if I have damaged the trans? It has been slipping when cold but no other problems.
wantdeath
NW Ohio
1992 Mazda Navajo
you are supposed to drop the axle because, from what ive been told, since the engine isnt running, the trans pump isnt running, and your not getting fluid to the rear seal. which will burn up that seal and cause a leak. as far as your trans slipping, maybe it got low on fluid and burnt up your clutches.
buckwill
trona calif
1998 sport
its not just the seal it also the bushing locating the rear slip yoke but also everything that the rear shaft is attached to, drums bearings clutch packs many things, but there trans guys here can tell more specifically.
safn1949
Location
Brookings Oregon
M60A1 my first offroader
If it slips when cold you are damaging the tranny by driving it and take my word for it,that there is a pricey fix.Towing an auto trans means no pump running = no lube = toast sooner or later.:D
druppel
Wildomar CA
96 xlt
Thanks for the great response. I'm going to check to make sure my fluid is full and see if it still slips when it is cold.
F150hybred
Arborg, Manitoba, Canada
1994 Explorer XLT
um... why not just put the transfercase in neutral? The pump in the case will still work and the trans won't be turning.
I dunno... call me crazy... but wouldn't that work?
arco777
1994 Explorer 2dr 4x4
T-case in neutral would work. However if someone reading this in future has a 2WD...
I have heard on some transmissions you can neutral tow if you stop every 50 miles or so and run the engine for a minute to circulate trans fluid.
Whether that's true for the A4LD or not, it's pretty easy to just unbolt the rear driveshaft at the axle and secure it up out of the way.
briwayjones
Manual Master
Location
Maryland, USA
Eldersburg, MD
2000 Ford Explorer XLS
Except if he has push button 4wd like most were and not a manual transfer case you can't put it in neutral.
druppel
Wildomar CA
96 xlt
Putting the transfer case in neutral would be great, but how do you do that with an auto trans and only dashboard buttons that do not include neutral. Is there a way to do this?
Also, stopping to run the engine could work, but dropping the drive shaft isn't that difficult. Running the engine while towing was suggested, but I would worry about it slipping into gear, and that would be a real mess.
Thanks for your input!
B Flat Towing 2000 Ford Explorer XLT Stock 1991 - 1994 Explorers 0
7 Trailer Towing Questions Stock 1991 - 1994 Explorers 2
T towing capacity question Stock 1991 - 1994 Explorers 17
N towing / lift inquiry Stock 1991 - 1994 Explorers 5
jprentice94 towing Stock 1991 - 1994 Explorers 13
E 93 for towing - buyer's remorse? Stock 1991 - 1994 Explorers 10
M 3.55's and towing Stock 1991 - 1994 Explorers 2
S light towing Stock 1991 - 1994 Explorers 7
O fuses, flashers and towing Stock 1991 - 1994 Explorers 4
U Towing with a stock 94 X Stock 1991 - 1994 Explorers 1
F Flat towing w/elec T case Stock 1991 - 1994 Explorers 4
P towing and no 4x4 Stock 1991 - 1994 Explorers 12
A Towing Question Stock 1991 - 1994 Explorers 3
R Towing capacity question Stock 1991 - 1994 Explorers 19
SwaintaN Towing/Hauling Question Stock 1991 - 1994 Explorers 12
P 94 limited used for towing a a little play/grocery getting. What shocks? Stock 1991 - 1994 Explorers 9
9 Towing wire harness Stock 1991 - 1994 Explorers 0
P 94 LMTD, Where can I find the Trailer/Towing electric Hookups? Stock 1991 - 1994 Explorers 14
M 94 Eddie B, Help! ATF Leak (Smoking!) when towing + other ?'s Please Help! Stock 1991 - 1994 Explorers 8
E ball for towing Stock 1991 - 1994 Explorers 8
J Towing Question Stock 1991 - 1994 Explorers 23
J Towing with manual transmission Stock 1991 - 1994 Explorers 2
B Explorer Sport towing U-Haul Trailer Stock 1991 - 1994 Explorers 3
S 1994 Towing - real world numbers? Stock 1991 - 1994 Explorers 3
S can I convert to factory towing wiring harness? Stock 1991 - 1994 Explorers 4
S Towing a motorcycle trailer on I-5; don't use OD? Stock 1991 - 1994 Explorers 0
I Max Towing For '91 4x4 Stock 1991 - 1994 Explorers 16
N towing Stock 1991 - 1994 Explorers 14
9 What makes up a towing package??? Stock 1991 - 1994 Explorers 42
D "check engine" light when towing up grades Stock 1991 - 1994 Explorers 10
6 Flat towing 1993 explorer Stock 1991 - 1994 Explorers 8
E 1994 Explorer 4x4 leaky trans Stock 1991 - 1994 Explorers 2
9 Anyone Know Gear ratio for rear diff in 1991 Mazda Navajo LX automatic Trans?? Stock 1991 - 1994 Explorers 4
massacre Trans Fluid Level Question Stock 1991 - 1994 Explorers 1
F manual trans will drive in 4 low Stock 1991 - 1994 Explorers 2
N Please help With auto trans Stock 1991 - 1994 Explorers 5
S Auto trans not shifting when cold Stock 1991 - 1994 Explorers 11
D 96 trans fit a 91 explorer Stock 1991 - 1994 Explorers 2
D Replacing A/C condenser and thinking about installing aux trans cooler... but Stock 1991 - 1994 Explorers 15
R auto trans vacuum modulator leaking? Stock 1991 - 1994 Explorers 2
T Should I buy a 91 ex with manual trans? Stock 1991 - 1994 Explorers 16
I A4LD- leaky transmission- front seal? requesting trans expert advice please Stock 1991 - 1994 Explorers 9
A 91 Explorer - Trans Won't Shift Stock 1991 - 1994 Explorers 34
T 1991 ford explorer manual trans Stock 1991 - 1994 Explorers 4
T Should I risk a trans flush? Stock 1991 - 1994 Explorers 8
T trans leak Stock 1991 - 1994 Explorers 9
T trans fluid Stock 1991 - 1994 Explorers 3
B AL4D had front seal replaced trans is now worse!!! Stock 1991 - 1994 Explorers 3
9 Trans issue A4LD Stock 1991 - 1994 Explorers 16
L is removing auto trans possible with y-pipe in place? Stock 1991 - 1994 Explorers 25
Similar threads
