  • We are aware of the issue with our internal search engine and we will be bringing it back online shortly. For now please use the Google search bar near the top of each page. Thanks, Rick
Toyo Kogo Transmission for the B2 Questions
Drobinson
Shelton, Washington
86 bronco II
I just picked up a B2 and found it had a bad transmission it is stuck in fourth gear. from the people i talked to the toyo kogo had changed the input shafts in 1986 to 1987 from the previous toyo kogo. any information on how to get information on rebuilds.
Drobinson
Shelton, Washington
86 bronco II
I am sorry I am new at this what are sticky Threads, and how do i find this information. thanks
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
If you look at the top of the transmission section where this thread is posted, you will see other threads which are "pinned" to the top of this section. They move positions when somebody makes a post, but they are always on the top of the transmission forum main page.
Drobinson
Shelton, Washington
86 bronco II
Thank you Brooklynbay.
I am woundering if a toyo kogo transmission fit a 2.9 that came out of a 2.8 between the years of 83 to 87, because i am getting two differnet stories. One says that the input shaft is different and the other is saying if you take everything from the clutch back to the diff. as long as the bell bolts up the same it could fit?
From what i heard the mazda transmission (toyo kogo) is pain to rebuild.
N Old Toyo Koygo 5 speed in an explorer? Transmissions & Transfer Cases 5
X Transmission failed Transmissions & Transfer Cases 2
D New member... In need of transmission help... Transmissions & Transfer Cases 1
R Hello everyone, question for you. I have a '03 ranger 3.0l w automatic transmission. I wanted to know the location of the test port on my trans. Transmissions & Transfer Cases 2
S 04 Ford Explorer Transmission and transfer case issues Transmissions & Transfer Cases 0
L Rebuilt transmission drives good but.. Transmissions & Transfer Cases 0
L Ready to install transmission.... or am i Transmissions & Transfer Cases 0
B Why does my transmission do this? Transmissions & Transfer Cases 5
C 2004 Ford Explorer transmission. Options? Transmissions & Transfer Cases 3
D Transmission issue? Transmissions & Transfer Cases 1
R 2014 Transmission Leak Transmissions & Transfer Cases 1
F Attempting to diagnose transmission issue Transmissions & Transfer Cases 4
I Damaged Transmission Case Transmissions & Transfer Cases 4
J 4.6L AWD New transmission not engaging Transmissions & Transfer Cases 11
I Transmission Issue, Possibly Servo Pins Transmissions & Transfer Cases 5
S Lost S/C bleeder screw inside transmission Transmissions & Transfer Cases 17
0 2007 Sport Trac 4x4 a really weird acting transmission Transmissions & Transfer Cases 13
N 5r55e Transmission ?Wiring Issues? Transmissions & Transfer Cases 4
D AJ1E Transmission servo kit - anyone? Transmissions & Transfer Cases 2
F Transmission problem Transmissions & Transfer Cases 1
T HELP 06 Explorer Transmission Issues Transmissions & Transfer Cases 1
D Transmission Won’t Move Transmissions & Transfer Cases 4
C Solved New 5R55S. The transmission slips. Transmissions & Transfer Cases 6
A 08 Ford explorer limited transmission question Transmissions & Transfer Cases 0
J 2000 5r55e front transmission leak Transmissions & Transfer Cases 2
D 2002 Transmission Transmissions & Transfer Cases 1
R Will a transmission from a 4.6 ford explorer work in a 4.0 explorer? Transmissions & Transfer Cases 4
K Transmission, clutch or what??? Transmissions & Transfer Cases 1
E How to refill a transmission [serious but stupid question]? Transmissions & Transfer Cases 4
R Solved Multiple transmission codes after sitting in storage. Transmissions & Transfer Cases 12
T 6R60 transmission upgrade to a 6R80 or swap. Transmissions & Transfer Cases 7
W 2006 Explorer Transmission Removal - Top 2 bolts Transmissions & Transfer Cases 5
S Not sure if the transmission shop is trying to rip me off! Transmissions & Transfer Cases 13
W transmission won't shift Transmissions & Transfer Cases 1
E 08 4.6 v8 eddie after water in transmission Transmissions & Transfer Cases 3
W 02 Explorer Transmission Leak Transmissions & Transfer Cases 11
J 94 A4LD Transmission slipped out of gear and now won't go into any gear. Transmissions & Transfer Cases 4
E Transmission slip when shifting gears Transmissions & Transfer Cases 1
K 2000 ford ranger transmission problems Transmissions & Transfer Cases 11
08EddieCA transmission swap - 2008 AWD into a 2WD Transmissions & Transfer Cases 6
B Transmission dipstick stuck after Changing valvebody Transmissions & Transfer Cases 1
B 03 Sport Trac Transmission Problem Transmissions & Transfer Cases 4
vroomzoomboom transmission compatibility Transmissions & Transfer Cases 6
B 5R55E transmission codes Transmissions & Transfer Cases 2
T A 4R55E was change to 5R55E during a transmission swap. Transmissions & Transfer Cases 22
J Greetings - Transmission swap for 1994? Transmissions & Transfer Cases 4
C 2002 explorer p0741 code. 5r55w transmission problems. OD light flashing. Transmissions & Transfer Cases 2
O 4R55 transmission p0775 error AJ1E OD servo fix? Transmissions & Transfer Cases 3
C What years will Ford explorer 94 transmission interchange? Transmissions & Transfer Cases 1
allmyEXes What kind of transmission do I have in my 1997 Explorer? Transmissions & Transfer Cases 3
Similar threads
