TPMS and Remote Keyless Entry antenna | Ford Explorer - Ford Ranger Forums - Serious Explorations
medic550
Somewhere
2015 PIU
Looking for the location for the module for RKE and TPMS. Just picked up one that goes into programming mode for TPMS and RKE however unable to program either and confirmed that TPMS Sensors are present in the wheels. A dealer placed a civi console in this utility and not sure where to look behind the AC controls for the antenna. Pics would be helpful.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Welcome to the Forum. :wave:
Not sure what you meant by "just picked one up"? Are you talking about the vehicle?
This refers to the retail Explorer but may help. Not sure if the PIU is different. Remote Start / Entry Antenna Location
medic550
Somewhere
2015 PIU
Yes I just got the vehicle. I am getting tpms fault and keyless and tire sensors not working. Civilian have the module in back of center console by rear seats. However in police I believe it’s somewhere under dash. But I need help locating.
medic550
Somewhere
2015 PIU
I found a part number for the module but am unable to locate where it would be on the vehicle.
BB5Z-19G481-U
bill32399
Oregon
15 Explorer PIU
The TPMS module is right below the 2 cigarette lighters under the radio. Pull off that panel and it should be attached to the back on the police version. It's probably missing or unplugged laying down under the console in that area if the dealer messed with it.
The Keyless entry part is built into the BCM. Depending on the year of the PIU this is usually turned off and needs to be turned on with Forscan and programmed. If you go to the Ford site you can pull up the same year Manual and look for the programming instructions to link the buttons.
medic550
Somewhere
2015 PIU
The TPMS module is right below the 2 cigerette lighters under the radio. Pull off that panel and it should be attached to the back on the police version. It's probably missing or unplugged laying down under the console in that area if the dealer messed with it.
yeah the cig panel was missing and I assume misplaced upon decommission. It has keyless but won’t work without that antenna. I have one on order now to replace it.
bill32399
Oregon
15 Explorer PIU
The Keyless entry does not use the TPMS module for its antenna unless you have Intelligent Access(IA) and an RTA module. PIU's don't come with this. The PIU/Base/XLT use the BCM for it wireless functions.
The panel on the PIU where the TPMS mounts would have to be removed if they put in a center console like you mentioned if it an OEM one.
