MrRothstein
- October 2, 2019
- Chicago, IL
- 2014 PIU
Howdy,
I've had constant issues with the "Tire pressure sensor fault." And it's not constantly on, it just comes on once in a while and then stays on for a while. Sometimes the while lasts for days, sometimes for hours. But it always comes back.
Today I had the sensors tested (while the fault was on) and the guy said they were all transmitting, so it may be the TPMS module.
Where exactly is the TPMS module located in the 2014 PIU and how easy or difficult is it to replace it? Is there a good tutorial out there? And can you also point me to the correct module to buy?
Also, will I need to have the system to relearn all the sensors after I replace the module? As far as I understand, I will need a separate gadget for that, too, yes?
Thank you!
Thank you!
