Tpms sensor fault
Digitalgp
Hudson valley
2007 Explorer Limited
So of course about a week or so after putting on new tires now that the temperatures have plummeted I get the tire sensor fault message coming up. Is there any way to disable it or is the only way to replace the dead sensor? I can live without it since I was driving and regularly checking my tire pressures before they even became a thing.
plasticseng
Central NC
2002 XLS
If you have Forscan, you can disable it in the GEM module. You can also leave it active, but go into the instrument cluster module to keep the warning off your dash.
It's not real straightforward. You have to find the right line of code, convert the setting from hexidecimal to binary, change the right character, and then convert back to hexidecimal to get the value to input back into the module. I'm not well versed in it, but I was able to hack my way through it one day to turn off TPMS in my wife's 2008 Explorer.
Rod Robertson
California
2010 Explorer XLT V8 4WD
Callsign
Ruddy
just did this with FORSCAN, and the toggle switch OBD reader for the Wife's 2009 Escape. Was lucky it had a plain english TPMS enable/disable option.
plasticseng
Central NC
2002 XLS
Sweet. I wish they all were like that.
W Another TPMS sensor fault Stock 2006 -2010 Explorers 2
T TPMS, Tire Sensor Fault Stock 2006 -2010 Explorers 5
D Date Code on Ford TPMS Sensor Stock 2006 -2010 Explorers 1
D TPMS Sensor Stock 2006 -2010 Explorers 2
D Replacement TPMS Sensor Stock 2006 -2010 Explorers 6
D TPMS Monitor Vs Sensor Error Stock 2006 -2010 Explorers 1
N TPMS Sensor Life Span? Stock 2006 -2010 Explorers 4
S TPMS Sensor Replacement Stock 2006 -2010 Explorers 2
B Greasing hubs and disabling TPMS Stock 2006 -2010 Explorers 3
D Intermittent TPMS Operation Stock 2006 -2010 Explorers 0
D Mysterious TPMS Problem Stock 2006 -2010 Explorers 3
D TPMS programming issue Stock 2006 -2010 Explorers 6
2 How do I know if I have the TIRE PRESSURE MONITORING SYSTEM (TPMS) Stock 2006 -2010 Explorers 4
G TPMS sensors - yes or no Stock 2006 -2010 Explorers 22
D TPMS Sensors Stock 2006 -2010 Explorers 11
G Question re TPMS Stock 2006 -2010 Explorers 1
S TPMS alternative part number needed Stock 2006 -2010 Explorers 9
B TPMS Faults? Stock 2006 -2010 Explorers 1
W 2007 xlt TPMS which one? Stock 2006 -2010 Explorers 9
D Orange Electronic LE6L2T TPMS Sensors Stock 2006 -2010 Explorers 1
D TPMS Sensors Stock 2006 -2010 Explorers 2
W '07 XLT - Replace TPMS sensors now ? Stock 2006 -2010 Explorers 7
B TPMS & RKE not working properly --- bad SJB? Stock 2006 -2010 Explorers 0
R Need help understanding TPMS Stock 2006 -2010 Explorers 5
M TPMS sensors expected battery life Stock 2006 -2010 Explorers 3
L Tpms Relearn Stock 2006 -2010 Explorers 27
P 08 LTD Getting new tires soon. TPMS questions Stock 2006 -2010 Explorers 10
F TPMS Repair Stock 2006 -2010 Explorers 20
BigNutz TPMS Module Stock 2006 -2010 Explorers 14
T TPMS Replacement-Repair Stock 2006 -2010 Explorers 13
L New set of TPMS sensors Stock 2006 -2010 Explorers 2
R TPMS question Stock 2006 -2010 Explorers 7
E HELP! TPMS Reset upgraded wheels/tires Stock 2006 -2010 Explorers 2
H Tpms band type senser replaced Stock 2006 -2010 Explorers 1
C TPMS replacement options 2008 Mountaineer Stock 2006 -2010 Explorers 6
B TPMS sensors Stock 2006 -2010 Explorers 5
0 TPMS Monitor batteries Stock 2006 -2010 Explorers 3
edwx Can't use FIX-A-FLAT with TPMS! Stock 2006 -2010 Explorers 16
J Disable TPMS? Stock 2006 -2010 Explorers 20
T New Tires and TPMS problem Stock 2006 -2010 Explorers 11
J TPMS question Stock 2006 -2010 Explorers 0
B Training 06 EB TPMS Sensors Stock 2006 -2010 Explorers 3
A TPMS reset Stock 2006 -2010 Explorers 10
J Switching wheel size and TPMS ? Stock 2006 -2010 Explorers 9
E 2006 TPMS Service/Reset Stock 2006 -2010 Explorers 0
S 07 Eddie Bauer 4.0l SOHC Bank 1 Sensor 1 Wiring Help Needed Stock 2006 -2010 Explorers 3
V Front abs sensor replacement Stock 2006 -2010 Explorers 1
H Wheel Speed Sensor Stock 2006 -2010 Explorers 1
digifoss Tire Monitor / Sensor Fault Stock 2006 -2010 Explorers 3
S 2006 Ford Explorer xlt tire sensor warning Stock 2006 -2010 Explorers 2
Similar threads
