- October 6, 2008
- Location
- Va
- chesapeake virginia
- '96 xlt 4x4
OK so with the sensor (tps) plugged in it gets a 4.02v on the reference with it unplugged it gets 4.82v on reference and with grounding to something other than the ground in plug it reads 5.02v I've changed the sensor and the plug and still getting the same result I'm scratching my head trying to think where the voltage drop could be coming from tested the pcm ground and the engine ground and there fine don't really know where to look next besides just taking things apart and putting them back together.
I'm reading like 4.32v at WOT I believe some small issues are because of this(semi rough idle and some stumbling on very light throttle from a stop )not to mention the clunk coming to a stop which I've ruled out driveshafts etc.. because it goes away for a bit if I reset the pcm,I know a bad tps can cause this and would like to get it fixed I cringe when coming to a hard stop.
