Trailer Brake Controller Recommendation? | Ford Explorer - Ford Ranger Forums - Serious Explorations
MtnCar
2013 Explorer Sport
This summer I will be towing a 17.5' travel trailer. Since it it over 1500 lbs the rental company requires a trailer brake controller in my vehicle. Looking for recommendations of what one I should get.
'13 Exp Sport w/tow package.
Thanks
Dennych1
New york
2013 explorer
Is it difficult to install brake controller in a 2013 explorer with tow package is it just plug and play if so where would be the wiring located.
Dennis
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
If you have the tow package, the wiring is already run from the hitch to the inside of the car. There should a port under the dash somewhere to plug the brake controller into. You need the brake controller and a Ford wiring harness.
Not sure on its location but as I said, it should be under the dash.
Hopefully someone who has done this will chime in.
Lewisra
Howell, mi
2017 explorer limited
Dennis
Should be plug and play, you might need to add or connect wiring if you want to charge a battery on whatever is being towed. Plug/wiring is under dash near drivers left foot. Or at least that's where it's been on every vehicle I've towed with, I don't tow with my explorer.
dco43054
cmh
20 XLT
Dennis
There is another thread, a couple years old, that has all the information you are looking for on finding the wiring and installing a brake controller. A search will find it for you.
IIRC, the wire is taped to another and above the brake pedal. I found mine by laying on my back in the driver footwell and illuminating the under dash area with a flashlight..
+1 on the Prodigy. Love mine. I use some heavy duty Velcro to attach it to the lower dash on the left side of the steering wheel.
And to the OP, I'd guess the trailer you intend to tow falls within the towing capacity - but I'd look at the specs and the towing guide for your year to make sure.
MtnCar
2013 Explorer Sport
Hi All,
Thanks for the info. I really appreciate it. I will order a Tekonsha P3 and harness. I like the Velcro mourning idea. I did verify the trailer is within spec. It has a dry weight of 2900 lbs., so loaded up it will be well under the 5000 lbs max.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
trump
Monongahela,Pa
2013 Explorer XLT
Prodigy
I am using the Prodigy and I didn't need the harness. The harness from my Explorer plugged right into the Prodigy.
Linux3
Location
Western NY
NY
2016 Explorer Sport
As you see I have a 2016 Sport. I'm guessing all Sport models have the full tow packages. Mine does and I didn't order anything special.
I will be towing a Passport 195RB travel trailer with a weight of about 3,600 lbs (dry) and I will be getting sway / load leveling hitch.
Questions:
1) Wired for a brake controller. Any comments on type / brand I should buy or just let dealer select.
2) Mirrors. Do I need to add some kind of extended mirrors? If so what type.
peterk9
Staff member
Moderator
Callsign
VE3
TheBigYahi
Syracuse, NY
2014 Explorer XLT
I tow a large tent trailer (3000lbs dry, 4000lbs max) and I use the Prodigy P2, as the P3 just added a fancier display and a memory for different profiles. You need the harness and as you can read above, the connector is under the dash. It was a real pain to get mine out as it was taped to another harness. Lost a lot of knuckle skin getting it free.
My favorite part of the P2 is using the "boost" profiles while on the highway. On initial braking the b1 setting applies 25% of the set braking power which helps keep the trailer in line and really adds to the overall stopping power in emergency situations. The boost settings are nearly undrivable for me at low speeds though, as even a light tap on the brakes starts hopping the trailer axle. It's very simple to change the setting while under way, so I don't mind jockeying with it a bit.
Stic-o
Elite Movie Star
Lake View Terrace, CA
'91 Navajo '99 X '19 Rngr
I run the P3 on my Super Duty, it's the one thing I kept from my old tow rig, and it was simple plug and play. No wiring. However you may need to install some fuses that are just empty from the factory. Aging just plug them in. Super Easy
midnightsun
2016 Explorer Sport
Gerald C
PA
2018 Explorer, XLT
Trailer Brake Controller for a 2018
I just leased a 2018 Explorer XLT with a class III factory tow package. I need advice for the best brake controller and where the cable plugs into the Explorer's factory trailer brake wiring.
peterk9
Staff member
Moderator
Callsign
VE3
