Trailer Lights | Ford Explorer - Ford Ranger Forums - Serious Explorations
Trailer Lights
Marc Svatora
Harbor Springs
2015 Interceptor Utility
I'm trying to hook up trailer lights on my 2015 interceptor utility. Unfortunately the location to put the T junction shown for the regular explorer doesn't exist. Instead of a nice and easy place to unhook a wiring harness and hook the trailer lights in there's some kind of police light hookup. Where is the junction I can clip the trailer hitch lights located at?
As an added bonus, the fuses for trailer lights are installed in the fuse box. Is there a trailer light hookup already installed somewhere?
KayGee
Farmington, MI
'16 & '17 PIU
Should be under the bumper cover behind the pass rr wheel. If you have no back up sensors, the wiring should just be capped off. You would remove cap, insert t plug and put cap in other end.
If you have a used piu that was in service, there's no way to tell what mods may have been done to it. You may need to post some pics.
Eric Z
Plymouth Minnesota
15 Explorer PIU
Exactly where the junction was on my 2015 and of course check that the fuse is in place, since mine was not and I had thought complex problem, that was simple fuse :)
Marc Svatora
Harbor Springs
Trying to post a pic but am having no luck so far.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Welcome to the Forum Marc.:wave:
Marc Svatora
Harbor Springs
Turned out it was in the right position. There was some sort of adapter on it and I was able to pull it apart. Now to figure out why the blower motor won’t work. Just replaced the resistor, no joy.
peterk9
Staff member
Moderator
Callsign
VE3
Fuse?
Marc Svatora
Harbor Springs
The resistor was bad , replaced it and nothing. Tested at the motor, it’s getting juice. Going to tinker with the motor and plan on replacing it.
Eric Z
Plymouth Minnesota
15 Explorer PIU
Going to bring this one back to life as I have a follow on question. So the place that installed my hitch used the above mentioned "T" connector, but some of the wire corroded and I have had to repair. But my question is: This T junction thing seems like a whole bunch of unnecessary wires, given that the other side of T junction is open (going nowhere). Would it not be far simpler to just have connector that plugs in and has ONLY trailer wires (in my case simple flat 4 wire) that come out of it?? If such an item exists, any ideas as to where I might find one or what the part numbers might be?? Mine came with the Ford "Ready for the Road" lights, if that makes any difference on this connector. Also if I could only figure out how to de-pin the plug removing all the excess wires I could replace corroded socket and life would be good. Thanks for any help you can provide.
