I'm a bit confused and this may sound like a stupid question but if I have the trailer tow package and I hook the brake controller (Prodigy) into the factory wired plug under the dash via the correct adapter (Tekonsha 3035P), is that it? Is the circuit breaker or fuse already installed from the factory. The reason I ask is because the factory provided pigtail that comes with the car (which I don't plan on using) has tags on it for running lights and brake light.
But thats already hooked up via the factory mounted 7 pin adapter on the hitch so why would you need to splice into them again?
Basically what I'm asking is this a plug and play unit with the proper adapter (one with no splicing)?
