If you look at the first portion on the factory gray connector you can see it has four female connectors. The second connector only has the two prongs you mentioned because thats all you need to power the license plate lights. Get the connector like the one I gave you in the link and connect them together and you should be fine. I have the same year as yours and it was plug and play. Also, I had that same set-up like the one in the pic Hopkins sent you and found out that I really didn't need to spend all that money for it.
