tbroecker01
- April 18, 2015
- West Bend, WI
- 2012 Explorer Base
I've done some research and reading of the owner's manual on my 2012 Base 3.5L V6 FWD. I have found that it has all of the relays and fuses required to tow a trailer already in the fuse box, both under the hood and in the vehicle. I have also found the factory connector behind the right (passenger) rear wheel well that can hookup to an aftermarket trailer connector such as the Curt C56172 Custom Fit Harness (or similar) found on http://www.etrailer.com/t1-2012_Ford_Explorer.htm
The question I have is that since my vehicle apparently my vehicles has the necessary components already installed for TRAILER WIRING;
What is the factory harness part number(s) for the 4-pin harness?? and 7-pin style harness??
I have already read the numerous forums on tow capabilities with and without the factory tow package and aftermarket hitches, so I'm up-to-date on that information.
