Djohnson
Elite Explorer<br><img src="/forums/images/djohnso
- July 12, 2000
- ILLINOIS
- '98 SPORT
After I installed the Trailmaster lift I soon found out that the stock driveshaft would not work. The stock joint that was at the transfer case would not cover the additional angle that the lift created.
I then began working on the alternitive to buying the $675.00 shaft that Trailmaster was selling.
I decided that I needed a regular double cardan joint at the transfer case. I made an adapter that would allow a four bolt pattern drive shaft bolt up to out six bolt transfer case.
Right now I have the shaft off of the truck. It drives very smooth. No vibrations at all.
As soon as I put the new shaft on, I get a slight vibration around 55 MPH and up. The vibration is not very bad. It feels as if I am running some very meaty tires.
I have checked all the obvious items...(balance of shaft and balance of adapter).
The model below is the adapter and a drawing of the shaft.
I don't know what to try next.
Thanks for any help.
DJ
DJ
