Tranny fluid question
edwx
Jacksonville, FL
2020 Ford Explorer XLT
My owners manual on my '06 X xls 4.0L (5R55S) calls for MERCON atf, not MERCON V. Is this correct? It seems that all I hear about is MERCON V. I'm only asking because typo's do occur. My '03 X did use the MERCON V. I used synthetic in the transfer case, but I'm thinking about doing the tranny fluid change and want to be sure what kind to use.
ZO6_Vette
Long Island
2006 EB
The manual clearly states that Mercon V is required for the 5R55S
edwx
Jacksonville, FL
You are correct? I re-checked the manual and it's definitely MERCON V for the 5R55S. I must have been looking at the transfer case or power steering specs. Sorry 'bout that. I'm assuming I can mix A full synthetic atf fluid with MERCON V, right?
Bill MacLeod
Hamilton, Ontario
06 Ltd V-8
You are correct? I re-checked the manual and it's definitely MERCON V for the 5R55S. I must have been looking at the transfer case or power steering specs. Sorry 'bout that. I'm assuming I can mix A full synthetic atf fluid with MERCON V, right?[/QUOTE]
Make sure the synthetic is rated for Mercon V. Especially if your trans is still under warranty.
edwx
Jacksonville, FL
I will , thanks.
