Deaf_Ford_Driver
- April 19, 2012
- South Jersey
- 2002 Explorer Limited Ed.
Hello all, I think I have a tranny problem on a 2 year old rebuilt tranny........This morning, I was about to start up my truck to get it inspected, I noticed that I left the key in "ON" position and realized I forgot to turn it off after using the code reader to ensure the truck will pass inspection. So that means the battery was dead, I grab my jumper cables and started it up, let it run to charge up the battery then shifted it to drive to head out to the inspection station....didn't engage, didn't feel the small jolt when the tranny engages. (I am deaf, mind you) so tried the Reverse, nothing....even the 1, 2, 3 gears. ARGH! then after realizing the gears won't engage so i shifted up to Park, there was a grinding feeling that wouldn't stop till I pulled the shifter out of Park. I tried again small grinding happened then finally stopped and I turned off the truck ........... So fellow Ford drivers, I hope you can help me fix this issue.
