Tranny Slips In Reverse | Ford Explorer - Ford Ranger Forums - Serious Explorations
diceccon
Rhode Island
'98 XLT
I have a 98 explorer XLT, 4 door, 2/4 wheel drive.
At first my tranny would slip when I put it in reverse now and again. On its own, the car would not shift into reverse, I would have to shift to other gears such as drive and park and then back to reverse in order to get it into reverse. As time has gone on, it happens more frequently, and I will have more trouble getting the car out of reverse. The car has not slipped in any other gears.
I was told once that I complete transmission fluid flush could alleviate if not completely get rid of my problem as my problem may not be a failing tranny, though I'm not sure. Is my tranny failing? If so, how long do I have left on it? I'd love to get through the summer on it, putting another 5k or so miles on it before I sell it off. If I can flush it out and fix the problem, then that would be great and I'd have no more problems.
Join the Elite Explorers $20 Get rid of the ads!
Elite Explorer members see no advertisements, no banner ads, no double underlined links.
. First register on the forum, then join the Elite Explorers to get rid of the ads!
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
Facimeor
1998 XLT
Aside from the obvious fluid level possibility, I would suspect that if its not the very common issue with the separator plate gasket blowout, its the orings on the reverse servo, the latter being the one I most likely suspect. Both can be done at the same time relatively cheaply. The stickies in the transmission section of this forum have all the info you need to do the job yourself.
BrooklynBay
Staff member
Moderator
Brooklyn, NY
diceccon
Rhode Island
'98 XLT
Re
I haven't checked the fluids or anything yet, as soon as school is out I'm taking it to a transmission shop, but I've just been wondering if I'm look at a $2000 rebuild or something less.
I got the car around three months ago, and I had the tranny checked out immedietly, but the specialists told me one of the noises was a vibration involving the running boards. Sometimes at speeds under 40 mph there will be a high pitch whirring noise beneath me that stops when I put on the gas, I'm assuming that's what the mechanics heard because it happens much more often, but I'm sure they could be wrong or could just be bs'ing me in order to get me out of the shop.
