YovannyRamirez
- April 2, 2014
- Northeastern Pennsylvania
- 2000 Ford Explorer
So it all started off when i blew my tranny cooler coming up a mountain. All of the tranny fluid moved up to the radiator. I replaced radiator and flushed out coolant and added fresh tranny fluid. Ran good for a week or two, shortly after, tranny started to slip coming into 2nd gear and also if i put drive (D) on a hill it will not kick in at all.
Replaced transmission, seal, and filter (got it off a yard of a truck that was rear ended, no shaft or chassis damage). Got tranny up and running runs good. However, i am still having the same slippage but now instead of 2nd gear it is doing it on 3rd gear. it feels like i lose acceleration for a split second and the truck slams itself into 3rd gear. The shifter takes all the gears fine but when i am driving it shifts really rough into 3rd. the fluid on this new tranny is clear and red no metal shavings or anything, and smells good. ????????????
P.S- i added 1 qt of TransX and it worked for a few hours, The next day i added some transmission fluid Lucas and it did not help at all.
Torque converter???
2000 Ford Explorer 4.0 V6 SOHC auto trans
Torque converter???
